Thanks. I still am a little suspicious of the screen and will give this a go when I can, but I'm running Flashfloppy rather than HxC on this one, so don't know it has the same long-right-button reset, but it does have a display probe time setting for the FF.CFG I could fiddle with.Maximilian wrote: 18 Nov 2024 18:11 I've also heard of defective screens that need an extra reset before working.
https://hxc2001.com/docs/gotek-floppy-e ... -oled.html
Note
If the OLED screen doesn’t appear to work and if you are sure about the OLED wire connections, try to reset the Gotek : Shutdown the machine, press the Gotek’s right button, switch on the machine and keep the button pressed during ~5 seconds. This will clear the internals settings and force the long screen detection process. Some OLED screens with factory defects need this to be detected properly the first time.
