Raven060 (luciodra build).
luciodra
Re: Raven060 (luciodra build).
Post by luciodra »
agranlund wrote: Wed Nov 12, 2025 8:22 pm
luciodra wrote: Wed Nov 12, 2025 7:55 pm Is it a must or is it necessary?
I saw that there are other works (PP or the Putnik drivers that I used on SatanDisk)?
Ah, sorry. Don't know if HDDriver in particular is a must. It's the only one I tried since I'm used to it from the ST.
What I meant to say is that some kind of Atari harddisk driver is necessary for running MagiC.
I haven't tried the PP driver, or some of the other alternatives.
Thank you !
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
luciodra
Post by luciodra »
I finally managed to install Magic, albeit with some difficulty, partly due to my lack of knowledge of Atari.
I proceeded to prepare the SD-IDE using the latest version of HDDrivers, which I had to purchase.
Once I copied the contents of the Raven software to C, including NVDI, I downloaded and copied Magic with the correct files (basically, I renamed MAGIC.RAM, placing it in the root directory and everything else).
It works, it's nice, and it has some compatibility issues (at least I think so).
Any suggestions on how to improve the whole thing without reading around? ;)
ET4000AX 1Mb T0
PicoGUS 2.0
bbisi
Post by bbisi »
@luciodra
Hi
i am a new raven user
it is running. Very good
Can you tell me wich uiptool you use. Can you send me this one
My network is with sting running and I can pin all networkadresses
but uiptool will not start
I can't see the output from uiptool
The next question: How can I power on the raven. Anytime I must hold the button, other time it come after 5 clips and so on
thank you
bernd
luciodra
Post by luciodra »
bbisi wrote: Wed Nov 19, 2025 6:28 pm @luciodra
Hi
thank you
bernd
The answer to the first question is that I use uip.tos provided in the Granlund distribution in the drivers/ne2000 folder. To use uip.tos you must disable sting in the auto folder either by renaming it sting.prx or by using xboot.
I didn't quite understand the second question: are you referring to the power button on the case or the button on the motherboard? However, you only need to press once...
ET4000AX 1Mb T0
PicoGUS 2.0
@bbisi your Raven should start up with the first press of the power button
Could I suggest that when this happens you get the serial log via com1 and post it in your own Raven topic. Then we can help you better.
bbisi
Post by bbisi »
Hi
I think there is no eth loaded
but wich info you must have
this ?
d0: 00000080 d2: 01080000 d4: 00000000 d6: 00e40000
d1: 00010001 d3: 01080013 d5: 00020101 d7: 00010010
a0: 00016e10 a2: 010293c6 a4: 00e3125a a6: 0000bb54
a1: 01039b60 a3: 00e38f4e a5: 00018014 a7: 0000aef4
pc: 4000dda8 sr: 2000 usp: 00018014
vbr: 00581a00 tc: 00008210 srp: 00581800 urp: 00581800
dt0: 00000000 dt1: 00000000 it0: 00000000 it1: 00000000
pcr: 04300601 bcr: 00000000 ccr: a0808000
Where can I see the loaded ethernet driver
bbisi
Post by bbisi »
And this on start
RAVEN060
CPU: M68060R6
SIMM0: 01000000
SIMM1: 01000000
SIMM2: 01000000
SIMM3: 00200000
Coldboot
InitHeap
InitUart
InitIkbd
InitMfp
InitMidi
InitI2C
InitRtc
InitCfg
InitVbr
InitMonitor
IkbdConnect
CKBD.250706A1 7812bps
InitAtari
InitVbr
InitMmu
InitEmu
InitTos
InitVga
32Kb VGA Bios at 800C0000
VGA GUI 1600S DATE:11/24/1994
CHIPSET:TSENG LABS ET4000/W32
1 MB display memory
16bit vgamem
Starting TOS
@bbisi that's showing a full startup and boot to Tos. What happens when it fails to start?
Re Network card. It needs to be rtl8019as compatible, see my network card topic for an example.
bbisi
Post by bbisi »
yes I have an rtl8019
With installed sting the ping is running over ethernet
from my Mac I can ping the raven
Then I deinstall sting, All with name sting I rename
Then I test uiptool.tos 54812k
but always break on start and very short time it shows something like eth failed to get .. usb..
usb ???? they don't find the network driver
bbisi wrote: Thu Nov 20, 2025 4:22 pm yes I have an rtl8019
Plug and play won't work with the uip tool, you need to set it to IRQ10 and address 300h.
