Raven060 (luciodra build).
luciodra
Re: Raven060 (luciodra build).
Post by luciodra »
Ok, assembled and seems to work well. Tomorrow it's IDE's turn... :D
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
luciodra
Post by luciodra »
Could someone take a photo of the byteswap adapter mounted on the motherboard?
Thank you !
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
luciodra
Post by luciodra »
Ok, everything seems to work and also the Byteswap adapter finally.
Can you recommend a filesystem for Atari st? Are there only PP and HDDrivers? They have high costs and this would only be justified for guaranteed operation on Raven, while I'm only doing some tests at the moment...
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
kodak80
Post by kodak80 »
HDDriver has a demo available that allows testing before buying:
https://www.hddriver.net/en/demo.html
luciodra
Post by luciodra »
kodak80 wrote: Wed Nov 12, 2025 9:41 am HDDriver has a demo available that allows testing before buying:
Yes, but it really has too many limitations.
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
Atarian Computing
Post by Atarian Computing »
luciodra wrote: Wed Nov 12, 2025 8:43 am Ok, everything seems to work and also the Byteswap adapter finally.
HDDriver is rock solid on the Raven. Highly recommended, used it for literally decades.
luciodra
Post by luciodra »
Atarian Computing wrote: Wed Nov 12, 2025 10:23 am
Ok, then I'll consider the purchase.
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
agranlund
Post by agranlund »
I'm using HDDriver here. Mine is a couple of versions old now but appears to work fine.
It should be said that for EmuTOS and MiNT you don't need any third party drivers.
For MagiC it's a must though.
And, for some theoretical future effort to get official Atari TOS running it would be too.
(I've been tempted myself but holding off such endeavours to maybe piggyback on work that may or may not be happening in the context of a different Atari-wannabe machine)
luciodra
Post by luciodra »
agranlund wrote: Wed Nov 12, 2025 7:43 pm I'm using HDDriver here. Mine is a couple of versions old now but appears to work fine.
Is it a must or is it necessary?
I saw that there are other works (PP or the Putnik drivers that I used on SatanDisk)?
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
agranlund
Post by agranlund »
luciodra wrote: Wed Nov 12, 2025 7:55 pm Is it a must or is it necessary?
Ah, sorry. Don't know if HDDriver in particular is a must. It's the only one I tried since I'm used to it from the ST.
What I meant to say is that some kind of Atari harddisk driver is necessary for running MagiC.
I haven't tried the PP driver, or some of the other alternatives.
