Raven060 (kodak80 build)
agranlund
Re: Raven060 (kodak80 build)
Post by agranlund »
kodak80 wrote: Wed Jan 28, 2026 11:46 am I have converted the KiCad IO shield template to an STL an merged it with another IO template. I have ordered some to see if they fit and they are in the post to me.
Oooh, that's awesome :)
I've been using one of those shields where you manually cut out from a grid but would absolutely love to have a real one like that!
If it's from the template that was on github I half expect you may need to make further adjustments and possibly a second rev after test-fitting the first one. (I just measured by hand and doubt I was lucky enough to get it exactly right on the first try)
kodak80
Post by kodak80 »
It's a little thing but this finishes the casing of the Raven. Not bad for a first attempt with merging the STL files. Fits fine around the ports (well done @agranlund ). Maybe a bit loose in the ATX IO hole, but I am happy with the outcome.
@agranlund I have created a Github Pull Request to add the STL to the Raven060 Github.
agranlund
Post by agranlund »
That's amazing @kodak80 !
I merged in the pull request.
For someone like me which is completely clueless when it comes to 3d printing, are STL files completely self contained in that I can just send it to someone or some company and they would automatically know what to do with it?
That is really cool! JLC can print metal ;)
Cool. I'll try printing it this weekend
kodak80
Post by kodak80 »
agranlund wrote: Fri Jan 30, 2026 9:08 pm That's amazing @kodak80 !
Yes, an STL is all that they need to print.
I am no expert with 3D stuff and still learning to use Blender so very happy that this worked first attempt.
The ones I had printed, were with PLA +, 0.1mm with 20% Infill
agranlund
Post by agranlund »
@kodak80 , I tried ordering the piece from JLCPCB but they wouldn't accept it because of this:
2)File errors are detected (broken facets, bad edges and bad contours), which will result in printing failure and damage of the part.
These errors occurred because there might be some accuracy algorithms difference of converting different format files between the different software or some hidden surfaces had not been deleted yet when drawing the structural surfaces.
I have no idea about any of this so I figure I'll instead check if someone at work has a printer and could be bribed into printing that file for me.
peters
Post by peters »
Don't forget that some people on here, like me, have 3D printers.
kodak80
Post by kodak80 »
agranlund wrote: Sat Feb 07, 2026 9:31 am @kodak80 , I tried ordering the piece from JLCPCB but they wouldn't accept it because of this:
The local 3D print company I used, had a repaired version on my STL they generated, so assume this was used by them to complete processing my order. You could try this version with JLCPCB. Both the original STL and the repaired STL still have the wording for the connectors which did not show on the ones I had printed. The repaired2 copy below has the wording removed and was auto-fixed using the Autodesk Meshmixer tool.
EDIT: JLCPCB would not process the updated STL files so I have removed these. My recommendation is to use the original one in Github and a local print company or your own printer.
Edit2: PCBWAY will process the Github STL file. Unfortunately, their payment options no longer include PayPal so will not be using them.
luciodra
Post by luciodra »
Great !
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
