Greaseweazle
HigashiJun
Re: Greaseweazle
Post by HigashiJun »
I didn't know the Drawbridge.
Seems really interesting though for such a tiny piece of hardware.
HigashiJun
Re: Greaseweazle
My LEDs should reach me tomorrow !
I decided to go for this kind of LEDs:
Should give a good result on the black case.
:D
HigashiJun
Re: Greaseweazle
Spent the afternoon on it, but the project is over and everything works as expected !
:D
External LEDS are fitted and they look not so bad.
Internal wires routed.
I preferred to file a bit here as the USB-C connector on the Greaseweazle could be potentially strained when cable is inserted.
Reading an X68000 floppy disc on drive 0 (took me some time to find the right jumper configuration on this drive):
Reading an Amiga disc on drive 1:
Everything is closed and ready to use, except the 4 rubber feet. I will stick them tomorrow.
I really don't have any regrets with purchasing this case. It's robust, well made and perfect for 2 drives.
8-)
