PiRTOII and ColecoVision Megacart builds
Re: PiRTOII and ColecoVision Megacart builds
Just arrived:
- HigashiJun
More yay
Should be able to get them started today, probably even finished.
Need to go find some ROM files
- HigashiJun
There are not so much components to solder, so you should be good today.
I think soHigashiJun wrote: Thu Oct 31, 2024 12:37 pm There are not so much components to solder, so you should be good today.
The only issue I have is that there is a diode on both boards that protects the console if the 5v is left connected to the Pi, but I can't find what diode to use. I suspect a 1n4148 would do the job but I like to be sure.
EDIT - Found the diode, it is a 1n4148
And built:
Also now programmed so I just need to find some ROMs and we're off to the races.
The blue PCB is also for Coleco, but I'm going to do that later.
Coleco cart tests great
Need to do the same for the Intellivision and then start adding more carts
I knew that TMS VDP blue and white display would appear at some point.
For sure!stephen_usher wrote: Thu Oct 31, 2024 3:41 pm![]()
