DFB1X: no ALT-RAM
Re: DFB1X: no ALT-RAM
They are all thoroughly tested when they are sent out so don't know why the RAM would fail . You would have to return one of them to me with your order number for me to investigate the issue, but my time is practically non-existent at the moment unfortunately, so could be a while before I can get around to looking into it.
Just to be sure you are not trying to run TTram while the booster is in disabled mode ? As that wont work. The booster has to be in 40/50mhz mode to use TTram. EG: No jumpers other than the ROM bank select jumper BS1.
BTW YAARTTT likely needs TOS to set the cookie before YAART will find the memory automatically, but that's a separate issue and not important is the manual run isn't working.
There is a updated YAARTTT as well viewtopic.php?p=74601#p74601
