2600 Composite mod
Re: 2600 Composite mod
PhilC wrote: 18 Apr 2019 19:50 You need a various pcb box. Icky probably has a label you could use once you've got one.
I did start putting all pcbs in a drawer a while ago.. but these pcbs seem to have pre-dated that "move".. Guess I will look again..
Which is fair enough as it was over a year ago you got them.
If you reorder them, I'd be willing to contribute towards a couple of them?
PhilC wrote: 18 Apr 2019 20:01 Which is fair enough as it was over a year ago you got them.
Can do.. im still looking... I might have binned them in another clear out a few months ago :roll:
:cheer: :cheer: :cheer:
Found these at the bottom of the "failed booster drawer" ...
Which has been reallocated to bin.
LMAO, always where you least expect them :)
I found these chips in "the pile" So must have been one of the chips I planned on using..
This one buffers and cleans up the Digital output from.. whatever the chip is called :)
FMS6146MTC14X
This one buffers and outputs Svideo
FMS6400
Though is hard to find other than "iffy" suppliers or sources..
Not much progress, but progress nonetheless....
Right, that's it, I'm digging it out this weekend and finishing it!
rubber_jonnie wrote: 25 Apr 2019 19:35 Right, that's it, I'm digging it out this weekend and finishing it!
You better hurry, sent Phil a board yesterday ;)
Can't find the second IC :(
Don't worry RJ, I'd have broken it before you've built it.
(Thanks exxos btw)
Return to “8 BIT CORNER”
Users browsing this forum: CCBot and 5 guests
