TF4060 Beta Program
TheoTheoderich
Re: TF4060 Beta Program
Post by TheoTheoderich »
What IDE do you mean?
The internal IDE of the A4000T is working fine. Makes no difference if with TF4060 installed or not.
I am also using a Buddha Plus One and its IDE is also working fine.
Where you ever, with any fw, able to see a disk in the TF IDE.
swinterstein
Post by swinterstein »
Hi all,
I'm a proud new owner of a TF4060 with a 68060 Rev6 CPU. However, getting it to work in my A3000 didn't go as smoothly as I would have liked..
I learned rule #1 the hard way: Always make sure that a CPU board in the A3000 is pressed down really, really, REALLY hard into the slot!
Also, I had to fight with the Amiga filesystem getting corrupt on my ZuluSCSI, which caused all sorts of trouble (e.g. WHDLoad would start, but lock up immediately). I don't know if that can be caused by a flakey CPU connection, but those where my whoes..
My current state is that the system is working at 50 MHz - after some weeks of on and off work.
For now, I have some questions:
- What is the meaning of the color bars after a cold startup - is that the TF4060 initializing itself successfully? While getting the card to work, I had white "snowflakes" on a grey background occasionally for a fraction of a second - is that a failure state of the board?
- I'm running under AmigaOS ROM 3.1.4. Sysinfo shows that all Libraries are residing in the card's address space starting at $08000000 so the ROM seems to be remapped/copied. That seems to happen automatically?
- Strangely enough, Sysinfo shows that dos.library is version 40.5 (e.g. KS 3.0), where it should be 46.x (like the other libraries from 3.1.4 ROM). I haven't tested without the TF4060, but could that in any way be related to the cards initialisation?
From Germany,
-Stefan
swinterstein wrote: Thu Sep 25, 2025 4:13 pm For now, I have some questions:
The colourbars are an amiga tradition for 060 accelerators. They show that the code to disable the FPU before exec starts has been run. Nothing more.
I dont understand this question. The rom modules get loaded in to ram because its expontentially faster than using it from rom. Is there a TF4060 question here? This question should really be directed at the AmigaOS developers.
Again this is not a TF related question. Ask the AmigaOS developers.
EDIT: I cannot support random question about AmigaOS. Sounds like your TF4060 is working as designed. There is no software in the TF except cpuspeed and ehide.device.
TheoTheoderich
terriblefire wrote: Mon Sep 22, 2025 3:03 pm Where you ever, with any fw, able to see a disk in the TF IDE.
Please excuse the late reply.
Yes, all CF cards or IDE hard drives that I connected to the TF were displayed in HDToolbox and I was able to format them correctly (using OS 3.2.x), but strange graphics errors occurred at low resolutions and the IDE often/randomly stopped working after read accesses.
When nothing is connected to the ehide.device, the card works perfectly.
Ok so there is something bad up with my 4KT
swinterstein
terriblefire wrote: Thu Sep 25, 2025 4:52 pm Sounds like your TF4060 is working as designed. There is no software in the TF except cpuspeed and ehide.device.
Thanks, that helps. Maybe my wording was a bit sloppy, but I also wanted to share my experiences with others.
terriblefire wrote: Thu Sep 25, 2025 4:52 pm I cannot support random question about AmigaOS.
You don't have to.
Return to “TF360”
