Exxos 4MB Ram Upgrade for C070789 - Different Issue
kbjunkie
Re: Exxos 4MB Ram Upgrade for C070789 - Different Issue
Post by kbjunkie »
But have you tweaked the socket pins as well as cleaning them?
This is what I meanviewtopic.php?f=17&t=1484&hilit=PLCC
Sometimes cleaning is not enough.
I did as you advised and it turned out to be the GLUE socket. Tweaked the pins with a pick and re-inserted GLUE - all back to normal again. I think I will replace the socket for good measure though as I have a few sockets left over from a previous project.
Thanks for all the help!
KbJ
kbjunkie wrote: Fri May 24, 2024 10:18 am
KbJ
Gladto hear it's working again :)
Be aware that the ST does not use a 'normal' PLCC socket.
They have a strange pinout that is nothing like the standard pinouts of today, so unless you have proper sockets as used in the ST, you won't be able to replace the GLUE socket.
Tweaking the pins is usually good enough to get the socket working for a long time, so I wouldn't worry overly about it.
rubber_jonnie wrote: Fri May 24, 2024 10:39 am Tweaking the pins is usually good enough to get the socket working for a long time
I concur also.
Removing the socket can be tricky and often leads to motherboard damages. The golden rule of electronics applies here, if it is not broken, then don't fix it!
kbjunkie
Post by kbjunkie »
Yup - I decided after posting that I would just leave it alone. Glad I did now since the socket is 'different'!
Thanks for all of the advice and help!
kbjunkie wrote: Tue May 28, 2024 10:29 am
You're welcome :)
Return to “RAM UPGRADES”
