Exxos's PiStorm blog
Locked
Re: Exxos's PiStorm blog
exxos wrote: Tue Apr 16, 2024 3:01 pm All just seems way to over complicated to me. Think I am just better sticking to windows stuff .
There's the Windows way and there's everyone else's way.
If you're used to one, the other will seem complicated. ;)
@Steve this is what came out from the copy..
Folder PATH listing for volume bootfs
Volume serial number is 9E81-4F92
J:.
³   bcm2708-rpi-b-plus.dtb
³   COPYING.linux
³   LICENCE.broadcom
³   issue.txt
³   cmdline.txt
³   bcm2708-rpi-b-rev1.dtb
³   bcm2708-rpi-b.dtb
³   bcm2708-rpi-cm.dtb
³   bcm2708-rpi-zero-w.dtb
³   bcm2708-rpi-zero.dtb
³   bcm2709-rpi-2-b.dtb
³   bcm2709-rpi-cm2.dtb
³   bcm2710-rpi-2-b.dtb
³   bcm2710-rpi-3-b-plus.dtb
³   bcm2710-rpi-3-b.dtb
³   bcm2710-rpi-cm3.dtb
³   bcm2710-rpi-zero-2-w.dtb
³   bcm2710-rpi-zero-2.dtb
³   bcm2711-rpi-4-b.dtb
³   bcm2711-rpi-400.dtb
³   bcm2711-rpi-cm4-io.dtb
³   bcm2711-rpi-cm4.dtb
³   bcm2711-rpi-cm4s.dtb
³   bootcode.bin
³   config.txt
³   fixup.dat
³   fixup4.dat
³   fixup4cd.dat
³   fixup4db.dat
³   fixup4x.dat
³   fixup_cd.dat
³   fixup_db.dat
³   fixup_x.dat
³   kernel.img
³   kernel7.img
³   kernel7l.img
³   kernel8.img
³   start.elf
³   start4.elf
³   start4cd.elf
³   start4db.elf
³   start4x.elf
³   start_cd.elf
³   start_db.elf
³   start_x.elf
³   cmdline-new.txt
³   tree.txt
³
ÀÄÄÄoverlays
        adafruit-st7735r.dtbo
        README
        act-led.dtbo
        adau7002-simple.dtbo
        adafruit18.dtbo
        adau1977-adc.dtbo
        akkordion-iqdacplus.dtbo
        ads1015.dtbo
        ads1115.dtbo
        ads7846.dtbo
        adv7282m.dtbo
        adv728x-m.dtbo
        arducam-pivariety.dtbo
        anyspi.dtbo
        allo-boss-dac-pcm512x-audio.dtbo
        allo-boss2-dac-audio.dtbo
        allo-digione.dtbo
        allo-katana-dac-audio.dtbo
        allo-piano-dac-pcm512x-audio.dtbo
        allo-piano-dac-plus-pcm512x-audio.dtbo
        apds9960.dtbo
        applepi-dac.dtbo
        arducam-64mp.dtbo
        audioinjector-addons.dtbo
        at86rf233.dtbo
        audioinjector-isolated-soundcard.dtbo
        audioinjector-bare-i2s.dtbo
        vc4-kms-dsi-lt070me05000-v2.dtbo
        audioinjector-ultra.dtbo
        audioinjector-wm8731-audio.dtbo
        audiosense-pi.dtbo
        audremap.dtbo
        balena-fin.dtbo
        camera-mux-2port.dtbo
        camera-mux-4port.dtbo
        cap1106.dtbo
        chipdip-dac.dtbo
        cirrus-wm5102.dtbo
        cm-swap-i2c0.dtbo
        cma.dtbo
        crystalfontz-cfa050_pi_m.dtbo
        cutiepi-panel.dtbo
        dacberry400.dtbo
        dht11.dtbo
        dionaudio-kiwi.dtbo
        dionaudio-loco-v2.dtbo
        dionaudio-loco.dtbo
        disable-bt.dtbo
        disable-emmc2.dtbo
        disable-wifi.dtbo
        dpi18.dtbo
        dpi18cpadhi.dtbo
        dpi24.dtbo
        draws.dtbo
        dwc-otg.dtbo
        dwc2.dtbo
        edt-ft5406.dtbo
        enc28j60-spi2.dtbo
        enc28j60.dtbo
        exc3000.dtbo
        fbtft.dtbo
        fe-pi-audio.dtbo
        fsm-demo.dtbo
        gc9a01.dtbo
        ghost-amp.dtbo
        goodix.dtbo
        googlevoicehat-soundcard.dtbo
        gpio-fan.dtbo
        gpio-hog.dtbo
        gpio-ir-tx.dtbo
        gpio-ir.dtbo
        gpio-key.dtbo
        gpio-led.dtbo
        gpio-no-bank0-irq.dtbo
        gpio-no-irq.dtbo
        gpio-poweroff.dtbo
        gpio-shutdown.dtbo
        hd44780-lcd.dtbo
        hdmi-backlight-hwhack-gpio.dtbo
        hifiberry-amp.dtbo
        hifiberry-amp100.dtbo
        hifiberry-amp3.dtbo
        hifiberry-dac.dtbo
        hifiberry-dacplus.dtbo
        hifiberry-dacplusadc.dtbo
        hifiberry-dacplusadcpro.dtbo
        hifiberry-dacplusdsp.dtbo
        hifiberry-dacplushd.dtbo
        hifiberry-digi-pro.dtbo
        hifiberry-digi.dtbo
        highperi.dtbo
        hy28a.dtbo
        hy28b-2017.dtbo
        hy28b.dtbo
        i-sabre-q2m.dtbo
        i2c-bcm2708.dtbo
        i2c-fan.dtbo
        i2c-gpio.dtbo
        i2c-mux.dtbo
        i2c-pwm-pca9685a.dtbo
        i2c-rtc-gpio.dtbo
        i2c-rtc.dtbo
        i2c-sensor.dtbo
        i2c0.dtbo
        i2c1.dtbo
        i2c3.dtbo
        i2c4.dtbo
        i2c5.dtbo
        i2c6.dtbo
        i2s-dac.dtbo
        i2s-gpio28-31.dtbo
        ilitek251x.dtbo
        imx219.dtbo
        imx258.dtbo
        imx290.dtbo
        imx296.dtbo
        imx327.dtbo
        imx378.dtbo
        imx462.dtbo
        imx477.dtbo
        imx519.dtbo
        imx708.dtbo
        iqaudio-codec.dtbo
        iqaudio-dac.dtbo
        iqaudio-dacplus.dtbo
        iqaudio-digi-wm8804-audio.dtbo
        iqs550.dtbo
        irs1125.dtbo
        jedec-spi-nor.dtbo
        justboom-both.dtbo
        justboom-dac.dtbo
        justboom-digi.dtbo
        ltc294x.dtbo
        max98357a.dtbo
        maxtherm.dtbo
        mbed-dac.dtbo
        mcp23017.dtbo
        mcp23s17.dtbo
        mcp2515-can0.dtbo
        mcp2515-can1.dtbo
        mcp2515.dtbo
        mcp251xfd.dtbo
        mcp3008.dtbo
        mcp3202.dtbo
        mcp342x.dtbo
        media-center.dtbo
        merus-amp.dtbo
        midi-uart0.dtbo
        midi-uart1.dtbo
        midi-uart2.dtbo
        midi-uart3.dtbo
        midi-uart4.dtbo
        midi-uart5.dtbo
        minipitft13.dtbo
        miniuart-bt.dtbo
        mipi-dbi-spi.dtbo
        mlx90640.dtbo
        mmc.dtbo
        mpu6050.dtbo
        mz61581.dtbo
        ov2311.dtbo
        ov5647.dtbo
        ov7251.dtbo
        ov9281.dtbo
        overlay_map.dtb
        papirus.dtbo
        pca953x.dtbo
        pcie-32bit-dma.dtbo
        pibell.dtbo
        pifacedigital.dtbo
        pifi-40.dtbo
        pifi-dac-hd.dtbo
        pifi-dac-zero.dtbo
        pifi-mini-210.dtbo
        piglow.dtbo
        piscreen.dtbo
        piscreen2r.dtbo
        pisound.dtbo
        pitft22.dtbo
        pitft28-capacitive.dtbo
        pitft28-resistive.dtbo
        pitft35-resistive.dtbo
        pps-gpio.dtbo
        proto-codec.dtbo
        pwm-2chan.dtbo
        pwm-ir-tx.dtbo
        pwm.dtbo
        pwm1.dtbo
        qca7000-uart0.dtbo
        qca7000.dtbo
        ramoops-pi4.dtbo
        ramoops.dtbo
        rotary-encoder.dtbo
        rpi-backlight.dtbo
        rpi-codeczero.dtbo
        rpi-dacplus.dtbo
        rpi-dacpro.dtbo
        rpi-digiampplus.dtbo
        rpi-ft5406.dtbo
        rpi-poe-plus.dtbo
        rpi-poe.dtbo
        rpi-sense-v2.dtbo
        rpi-sense.dtbo
        rpi-tv.dtbo
        rra-digidac1-wm8741-audio.dtbo
        sainsmart18.dtbo
        sc16is750-i2c.dtbo
        sc16is752-i2c.dtbo
        sc16is752-spi0.dtbo
        sc16is752-spi1.dtbo
        sdhost.dtbo
        sdio.dtbo
        seeed-can-fd-hat-v1.dtbo
        seeed-can-fd-hat-v2.dtbo
        sh1106-spi.dtbo
        si446x-spi0.dtbo
        smi-dev.dtbo
        smi-nand.dtbo
        smi.dtbo
        spi-gpio35-39.dtbo
        spi-gpio40-45.dtbo
        spi-rtc.dtbo
        spi0-0cs.dtbo
        spi0-1cs.dtbo
        spi0-2cs.dtbo
        spi1-1cs.dtbo
        spi1-2cs.dtbo
        spi1-3cs.dtbo
        spi2-1cs.dtbo
        spi2-2cs.dtbo
        spi2-3cs.dtbo
        spi3-1cs.dtbo
        spi3-2cs.dtbo
        spi4-1cs.dtbo
        spi4-2cs.dtbo
        spi5-1cs.dtbo
        spi5-2cs.dtbo
        spi6-1cs.dtbo
        spi6-2cs.dtbo
        ssd1306-spi.dtbo
        ssd1306.dtbo
        ssd1331-spi.dtbo
        ssd1351-spi.dtbo
        superaudioboard.dtbo
        sx150x.dtbo
        tc358743-audio.dtbo
        tc358743.dtbo
        tinylcd35.dtbo
        tpm-slb9670.dtbo
        tpm-slb9673.dtbo
        uart0.dtbo
        uart1.dtbo
        uart2.dtbo
        uart3.dtbo
        uart4.dtbo
        uart5.dtbo
        udrc.dtbo
        ugreen-dabboard.dtbo
        upstream-pi4.dtbo
        upstream.dtbo
        vc4-fkms-v3d-pi4.dtbo
        vc4-fkms-v3d.dtbo
        vc4-kms-dpi-generic.dtbo
        vc4-kms-dpi-hyperpixel2r.dtbo
        vc4-kms-dpi-hyperpixel4.dtbo
        vc4-kms-dpi-hyperpixel4sq.dtbo
        vc4-kms-dpi-panel.dtbo
        vc4-kms-dsi-7inch.dtbo
        waveshare-can-fd-hat-mode-a.dtbo
        vc4-kms-dsi-lt070me05000.dtbo
        vc4-kms-kippah-7inch.dtbo
        vc4-kms-v3d-pi4.dtbo
        vc4-kms-v3d.dtbo
        vc4-kms-vga666.dtbo
        vga666.dtbo
        vl805.dtbo
        w1-gpio-pullup.dtbo
        w1-gpio.dtbo
        w5500.dtbo
        watterott-display.dtbo
        wm8960-soundcard.dtbo
        wittypi.dtbo
        waveshare-can-fd-hat-mode-b.dtbo
Just goto amazon and pick up a Sandisk 32gb card next day delivery for £10..... no stress then. You do realise you could use a bigger card also? Like a 64gb? It would work too.
ps - it has only written 1 partition. not the entire image to disk. You should use a dedicated app designed for writing disk images, like rufus or win32diskimager or balena etcher.
Steve wrote: Tue Apr 16, 2024 8:10 pm Just goto amazon and pick up a Sandisk 32gb card next day delivery for £10..... no stress then. You do realise you could use a bigger card also? Like a 64gb? It would work too.
Yep, will have to order one.
That was done with rufus.
Will have to leave it for a few days now anyway because my hands are hurting too much again. Cannot really do much until my board's come back from fab anyway.
Steve wrote: Tue Apr 16, 2024 8:10 pm ps - it has only written 1 partition. not the entire image to disk. You should use a dedicated app designed for writing disk images, like rufus or win32diskimager or balena etcher.
Windows is only ever going to see one partition, isn't it? Only boot is FAT32.
Does that SD card boot on the Pi, @exxos?
Making these Pi images is really straightforward normally. Why didn't the Pi Imaging software work?
Badwolf wrote: Tue Apr 16, 2024 9:47 pm Windows is only ever going to see one partition, isn't it? Only boot is FAT32.
True. I've not checked in Linux.
I've not tried it as I wouldn't know unless it connects to WiFi.. but that card has @Steve settings which wont work on my network... That's another problem..
Because @Steves 32GB card is 640MB larger than my 32GB card and it won't save the image.
@Badwolf This is what MX has.. I can't access rootfs though..
exxos wrote: Tue Apr 16, 2024 10:25 pm @Badwolf This is what MX has.. I can't access rootfs though..
That looks ok.
sudo mount /dev/sdg2 /mnt
Should make that available under /mnt, but this all seems very complicated to me.
exxos wrote: Tue Apr 16, 2024 9:58 pm
Ah, you haven't got the micro HDMI cable yet?
I meant the normal install. I didn't understand why you abandoned that approach. Does that let you preconfigure all of this then you just log in and copy what you want from Steve's image?
Badwolf wrote: Wed Apr 17, 2024 10:08 am I meant the normal install. I didn't understand why you abandoned that approach. Does that let you preconfigure all of this then you just log in and copy what you want from Steve's image?
Because @Steve said there was loads to configure and he hasn't tried the latest firmware yet. His setup works on the H5. So he wanted me to have a more "plug and play" experience. Nobody AFAIK has tested the latest firmwares , so it could be broke for all we know on the H5 now.
My HDMI cable has come, but I'm not at home today and need to keep off the pc for a few days now anyway. All this Linux stuff isn't RSI friendly.. I can't type more than a couple of sentences each day before I am in a lot of pain :(
exxos wrote: Wed Apr 17, 2024 10:18 am My HDMI cable has come, but I'm not at home today and need to keep off the pc for a few days now anyway. All this Linux stuff isn't RSI friendly.. I can't type more than a couple of sentences each day before I am in a lot of pain :(
Ah, yeah. Getting a PiStorm going will involve a lot of typing, I'm afraid. :(
Locked
