redpixel
Post by redpixel »
agranlund wrote: Sun Jun 07, 2026 12:29 pm I don't have anything particularly clever to add other than I have the same card showing up in ISA_BIOS and working.
That's not saying there couldn't be some kind of incompatibility from Raven or ISA_BIOS but at least a data point showing it working in one machine.
We could probably make an ISA_BIOS with extra debug logging, and maybe a new Nessi firmware with a few more ISA waitstates if that's the issue.
Thanks for the good suggestions! I bought the card just because I saw that you also had it so I was sure that you would do magical things with it :D
I tried to add 2 extra wait states in Nessi, just slapping them onto the "end", i.e. counting up to ISADTACK22 instead of ISADTACK20. That did not make any difference. I also tried to replace the 68150 with another one (the one I normally use is FN40 and I tried to replace it with another FN33 that I have). Also no difference.
Then I tried to use different bus/CPU oscillators, and boom, it showed up! So I guess it is somehow timing related, but it doesn't seem to help adding wait states at the end. My testing looked like this:
OscNessi 251029Nessi +2 waitstates
25 MHzDetectedDetected
32 MHzNo bootNo boot
40 MHzDetectedDetected
48 MHzNot detectedNot detected
CPU was at X2 in all cases. I have normally used the 48 MHz oscillator. In the No boot case it hangs on InitVga (I'm using an ATI Mach32 2 MB, I believe exact same model as you have also... :P That was by chance though!)
Not sure if you have any ideas what could be wrong, otherwise I can see if I can hook up my logic analyzer and try to measure a bit and see if I can make any sense of it. I think I might have to order one of those ISA extender PCB's for that though, to be able to have some accessible probe points.
mikro
Post by mikro »
agranlund wrote: Sun Jun 07, 2026 12:47 pm Probably what needs to happen now for a more polished experience is:
- detach mouse cursor redraw from main loop.
some gfxcards has support hardware cursor but for best compatibility I think a software solution like in ScummST would be first priority.
(just redraw the cursor at every VBL if changed, essentially)
- detach music from main loop.
avoid midi/adlib timing jitter as well as stalls if mainloop is busy for a length of time (loading etc)
Perhaps not accidentally, I have looked into same things lately (although only on a theoretical level). VBL based cursors gets *very* tricky once you want to keep triple-buffering in place. Of course, not impossible to overcome and especially if you have true hardware cursors available, that way you don't have to solve dirty rects.
MIDI timing is a bit easier because audio code is assumed to work in a separate thread but then there's the issue I had been fighting for a while (and put it on hold to look into less frustrating things) -- how to actually keep the multithreading part while not stepping into the complex locking/unlocking territory.
But maybe both issues need just a fresh pair of eyes and you are definitely the best candidate for that. ;)
Btw, while waiting for my family at Brisbane airport:
kodak80
Post by kodak80 »
mikro wrote: Mon Jun 08, 2026 12:34 am Btw, while waiting for my family at Brisbane airport:
Wow, that is a big coincidence. :) It's a sign...of good things to come.
Also, guess I won't be getting that rego.
agranlund
Post by agranlund »
Haha, that is amazing!
agranlund
Post by agranlund »
Yay! Raven rev.A2 arrives :)
Probably wont have time to solder one up until next weekend or so but was still always exciting to open the package and seeing the pcb as a physical thing rather than a project inside Kicad.
Fingers crossed everything then actually works as intended too :)
Cyprian
Post by Cyprian »
looks great,
I'm very curious about the DSP itself
http://260ste.atari.org
Look at all that black and gold :cheer: :cheer:
LarryL
Post by LarryL »
wow - looks extremely beautiful!
Oh my God — how can I stop myself from giving in? :o :roll:
agranlund
Post by agranlund »
Slowly, most of the top-layer SMD components are in place.
I had forgotten how much work it was to assemble it... :)
