You definitely made something better! This is with the Mach64:agranlund wrote: Mon Dec 15, 2025 10:10 am Latest release zip has an updated rom which now maps in the entire 16MB isa-ram range.
@redpixel , might be worth testing the Mach64 the same way as before again, letting the Mach64 nova driver activate regardless if you're getting a picture directly from bios or not.
After this, I don't think I can do a whole lot without such card in my machine.
It seems to be really sensitive. I saw some minor graphical corruption and one start-up freeze (when loading NOVA) with the Mach32, so I tried switching to the 40 MHz oscillator (instead of 48 MHz which I was using previously). When I used the 40 MHz oscillator the Mach64 hung in the InitVga stage (when trying to execute the VGA BIOS), both with X1 and X2 (not sure if that affects the timing of ISA bus accesses). The Mach32 seemed to work OK with the 40 MHz oscillator, although I haven't run any type of benchmarking or so (only boot-ups).
When I switched back to the 48 MHz oscillator and X1 mode the Mach64 manages to "run" the VGA BIOS (or at least InitVga returns), but it still gives the 8-bit vgamem message and no further print-outs and the screen stays black. After NOVA initialisation you actually see something (at 1024x768x8). Redraw seems to be non-functional though and there are some artifacts.
If you want I can of course send you my board, or maybe I could try to do some debugging on my own if I manage to get up-to-speed with how to build the ROM etc.
