Apples aren't the only fruit.
Re: Apples aren't the only fruit.
stephen_usher wrote: Fri Mar 01, 2024 9:03 am One more throw of the dice. Self adhesive acoustic foam this time.
Keeping my fingers crossed!!
Can't believe I've yet to find a machine with a foam & foil keyboard.
Probably won't work, but have you tried a dome from an ST keyboard?
rubber_jonnie wrote: Fri Mar 01, 2024 12:01 pm
That's both conductive and way too small an area. You need to fill the 11mm circle with capacitative material.
stephen_usher wrote: Fri Mar 01, 2024 12:55 pm
Fair enough.
Well, the new "acoustic" foam seems to work well at least. Swapped it over on the space bar and it works a treat.
Redone all the keys that I did last night and they all work nicely. I think I've found the correct materials at last.
stephen_usher wrote: Fri Mar 01, 2024 10:02 pm Redone all the keys that I did last night and they all work nicely. I think I've found the correct materials at last.
:girldance: :girldance: :girldance:
:cheer: :cheer: :cheer:
HigashiJun
Post by HigashiJun »
:girldance: :yay2: :girldance: :cheer: :girldance:
The foam and "foil" production line...
What was the magic ingredient then?
