Mega ST Hard drive mount
IDE, ACSI etc kits and products.
atari030
Re: Mega ST Hard drive mount
Post by atari030 »
I think I have a solution. A plastic 3.5" to 5.25" floppy bracket. Drill four holes, add four 1cm bushes and that should work. Its bloody tight though. Basically the same way the floppy drive is mounted. Now to find some bushes the right size.....
!Message from: Moderator
@atari030, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
frank.lukas
Post by frank.lukas »
I still had an ICD box from a micro adapter and this sheet metal was included I think. No idea how it fit ?
atari030
Post by atari030 »
Thanks Frank, this is sort of what I'm planning on. That plate would work the same way, it would use bushings. The screw holes match. I might just recreate it with ABS sheet.
atari030
Post by atari030 »
Well ABS was too flexible so I went with a ply sheet and some Supermicro standoffs. Works a treat.
Return to “HARD DRIVES”
