chronicthehedgehog wrote: Mon Apr 01, 2024 1:01 pm
I've got 40 SN74LS76AN on my shelf if you need more. I bought a good job lot a couple of years ago. I got a bit OCD about 74X at the time
Much appreciated.
I do have some coming, but will give you a shout if I run into problems, thanks.
Quick update, I put together a quickie video buffer that slots into the 2 unused sockets at the top of the board, and picks up 5v & GND to power it.
Video out on my LCD is pretty nice from it and I now have 2 outputs, one for CRT and one for LCD
Well, my 7476's arrived and it's made no difference to the tape output. Hmm
What's weird though is that pin 11 outputs to R56, a 100K resistor, and on the IC side there is a signal, but on the other side of the resistor, that connects to pin 9 of J2, there isn't. t
Pin 9 of J2 connects to pin 7, the cassette out, via a voltage divider.
The resistor measures fine, however there is a capacitor, C13 between the output of R56 and GND. Could I have got this cap wrong as well? So I need to check that and see if lifting one leg changes what I see on pin 9 of J2.
It should be 0.01 uF. I can at least check that, though for now further testing has to go on hold as an LS163 in my video circuit has died and guess what? I don't have any spares!!!
I have, I'm sure, nearly every 74 series IC ever made (Maybe I'm exaggerating ), but I never have the one I actually need. So the OSI will have to wait a couple of days.
More and more I'm thinking I accidentally powered my bench PSU on at 8.5v and that's why so many have died. Meh!
Do you see a signal if you lift the non-chip side of the resistor and/or remove the cap?
Annoyingly I didn't get that far before the LS163 in the video circuit decided to go bye bye.
I will probably pull one leg of the cap to check the value at least, and I may be able to blind type to see if I get anything with the cap lifted/removed.
Just wondering if I've filtered myself again...
One other thing I'll be doing once I have this up and running again is to fix the problem of the display being shunted 2 characters to the right, which is very noticeable on the LCD.
So I have modded the ROM file at location $7E0 after discussing over at OSIWeb, and once I have some new ROMs (My current ROMs aren't erasable) I'll flash it.
It just requires that value to be changed from $65 to $63, which will shift it 2 columns left. Increasing the value moves it a column to the right, decreasing moves to the left. Apparently you can also add or subtract $40 from that value to move the bottom left corner up or down too, however that's not necessary for me.
I'll report back on the results.
Well I lifted a leg on the cap and tested it, it is indeed the correct value, 0.01uF. I'll leave the leg lifted until I can get the video fixed and will look at it again then.
The LS163's are from a supplier who I trust so I expect them to be here in the next few days.
