ACORN A5000 inbound
HigashiJun
Re: ACORN A5000 inbound
Post by HigashiJun »
Some little progress:
On of the 74HCT245T buffers is now fitted.
The other one has to wait, due to 2 or 3 tracks not having continuity.
The RTC is also soldered and has one track fixed (blurry pic):
And to finish today's post, some new tracks repaired:
That's all for today.
Lovely work I have to say, well done.
HigashiJun
@rubber_jonnie
Thanks, but it's not over yet.
I keep my fingers crossed and I hope the machine will live again.
:crossed1:
HigashiJun wrote: 28 Nov 2023 11:26 @rubber_jonnie
:crossed1:
With you in spirit :)
HigashiJun
:cheers:
HigashiJun
Small update today.
Via repaired with an eyelet and pins fitted for future battery connection.
The battery will be placed in this holder.
And for fun, I powered on the A5000 (without battery, and track repairs still pending) and was greeted by this nice screen, with a cursor only.
At least, there's a sign of life...
:D
Did you try booting with Del held down? Should reset the cmos and boot up to Risc OS from ROM.
HigashiJun
Yes, but nothing happened.
The cursor appeared after another key was pressed ('R' or 'T')...
It was just a try and I didn't care too much... Some jumpers may be incorrectly set, and some tracks are still left for repair.
To reset the CMOS it's hold down R and power-on on most Archs.
stephen_usher wrote: 29 Nov 2023 11:40 To reset the CMOS it's hold down R and power-on on most Archs.
From what I can see, R or Del should do the reset, and it 'should' work, but I think the next step would be to get the floppy drive connected up to see what, if any, the blink codes are.
Users browsing this forum: CCBot, jmorden, luciodra and 14 guests
