Tried the firmware which is posted on page 1.
This maps stuff differently indeed.
But still no FM music and the memory issue seems comparable.
Now mapped 64kb on slot 3 vs 2 with original firmware. The other 64kb is mapped at the slot were the mem expansion is but this mem is gone then…. And the other mem is not seen by this testrom.. Is there maybe an updated firmware? I could not find it on the tf github.
Tinyslot as rom file booted from pico MSX menu:
:o)
:o)
TFMSX rev 2 features & problems
Oldskool
Re: TFMSX rev 2 features & problems
Oldskool
Will send the tfmsx to the pico msx guy.
He will probably find the issue…
- Admin sponsor
ok thanks. if there is a change needed my side i can do it.
i'm pretty sure that if there were sound output you would hear it. maybe a clash
Oldskool
@terriblefire
Tfmsx is now at Jeroen he was wondering if he could potentially have a look at the source code if he found issues. Not sure what is handy. Maybe he could contact you directly somehow for discussing this. I can imagine that you also don’t want some strange guy fiddling with your code…
His preferred email is:
msxpico@gmail.com
msxpico@gmail.com
- Admin sponsor
I've dropped an email. i can for sure give the pertinent equations to him.
- Admin sponsor
Right think i have spotted the issue.
CPLD always outputs high or low and thus the Cart cannot assert /WAIT. Its an easy fw fix but unfortunately i think its missing a pull up to let the CPLD go high impedance. We might need to graft on a pull up resistor.
Oldskool
Could you send the updated experimental Jed file to Jeroen? Including the resistor mod?
- Admin sponsor
experimental jed here..Oldskool wrote: 21 Sep 2024 13:42 Could you send the updated experimental Jed file to Jeroen? Including the resistor mod?
Resistor mod is just a resistor between 500R and 1K between Wait and VCC on the Z80
- Admin sponsor
I've had feedback that this has fixed the issue. I suppose i should do a 2b version of the board.
Oldskool
As far as understand it from the Discord discussion the status is that the fmpac now works. The memory mapper does however not seem to work so always 64kb.terriblefire wrote: 22 Sep 2024 16:17 I've had feedback that this has fixed the issue. I suppose i should do a 2b version of the board.
But the great news is that we can play Aleste with FM..
