Now how the heck do you use this things as it's been over 20 years
LLOYD L9000 PROGRAMMER REPAIR
Re: LLOYD L9000 PROGRAMMER REPAIR
Ah, some idiot might have mixed up the 2 DIP8 IC's
I guess that you have to learn French first.
There is a language settings somewhere
You can find out once you learn French.
So the next problem is the far right gang does not appear to be working
I swapped the EPROMS around and it had no effect.
So I swapped the panel (bank of 4) with the other side and the form as well. So that fault is definitely on the panel!
After continuity checking the EPROM to the bottom pins, it was clear there was several things not contacting. Oddly the ZIF sockets actually seem to be in sockets!
Unsoldered the thing. Afterwards I realised I probably needn't have bothered doing this!
Removed the two tiny screws.
Gave it a good dose with contact cleaner spray.
Then back together again. Now continuity checks all fine!
Quick cleanup.
Sockets soldered back in.
Hurray!
Next up to get a serial link to my PC!
Quick cleanup.
Hurray!
Yay!
That does look a nice bit of kit, not that I ever have to burn more than one rom at a time but I bet you enjoyed the challenge of getting it running again.
Not really
Next problem is I get "framing error". No idea why.
The manual says:
The manual says:
I have matched the programmer to what it is set in windows but makes no oddsRS232-Framing
While receiving data through the RS232 port, a framing error has occurred because
a valid stop bit has not been detected. Check that the baud rate, number of data and
stop bits, and parity are the same for both the programmer and the remote
computer.
@exxos are you using a USB serial or a proper one on the computer MB? Some old stuff I used to use would not work with USB adaptors.
