They aren't the easiest when it comes to TCP/IP. For file transfer I found Sunfish/Moonfish worked well for NFS shares. Looking good.HigashiJun wrote: 28 Nov 2024 09:18 It's been a long time since my last post in this thread.
Yesterday and today I managed to find some free time to tinker with my ethernet podule.
Getting it to work was simpler than I thought, but I cannot say it was plug and play either...
I now use Uniboot2 instead of Uniboot31 due to the fact I couldn't get the podule to work with the last one.
After setting the Inetsetup app, I also had to change some parameters in the Startup file.
Omniclient and FTPc are already installed in the Archie and I now have to figure how to connect to my Mac (but cleaning my desktop of its dust is more urgent). :oops:
Archie A3000 inbound
Re: Archie A3000 inbound
HigashiJun
Don't those 2 need an external library in order to get them run ?rubber_jonnie wrote: 28 Nov 2024 09:25 They aren't the easiest when it comes to TCP/IP. For file transfer I found Sunfish/Moonfish worked well for NFS shares. Looking good.
I've also heard they are memory hungry, and my 4 MB are easily full...
I can't remember which one is a memory hog, but yes, one is. Trouble is, getting anything else but those working on my A5000 just didn't happen.HigashiJun wrote: 28 Nov 2024 09:34Don't those 2 need an external library in order to get them run ?rubber_jonnie wrote: 28 Nov 2024 09:25 They aren't the easiest when it comes to TCP/IP. For file transfer I found Sunfish/Moonfish worked well for NFS shares. Looking good.
HigashiJun
@rubber_jonnie
And do you exchange your files between your Mac or a Windows PC ?
I couldn't get it to work with my Mac, which is an M1 MBP, but I was able to make it work with both Windows and Linux.HigashiJun wrote: 28 Nov 2024 09:50 @rubber_jonnie
HigashiJun
Ah bummer...rubber_jonnie wrote: 28 Nov 2024 10:16 I couldn't get it to work with my Mac, which is an M1 MBP, but I was able to make it work with both Windows and Linux.
I hope I have more luck with my Intel Mac.
My workbench PC is a 2012 Intel MBP with boot camp, so I might try that, but I do recall having issues using Win 10, but on my 2016 server it was all fine, same for a Linux laptop I built.HigashiJun wrote: 28 Nov 2024 10:37Ah bummer...rubber_jonnie wrote: 28 Nov 2024 10:16 I couldn't get it to work with my Mac, which is an M1 MBP, but I was able to make it work with both Windows and Linux.
I could never get SMB or FTP working at all.
HigashiJun
Not very encouraging...
No. What's worse is I think I have another issue as booting today it's just crashing and all my customisations are gone, and no sign of my BlueSCSI :(
More for the project list, wondering if it's the CMOS as I recently replaced the battery and when it did boot the clock was way off.
Also if I leave it I get random beeping and on screen corruption. Could be bad RAM I suppose.
EDIT - Think I have a BlueSCSI image issue, need to replace with a backup. Maybe swap SD as well.
HigashiJun
@rubber_jonnie
Hate that kind of situation...
Everything works smoothly and then suddenly you encounter issues you never had before.
Hope for you it's just the Blue SCSI image.
:crossed1:
:crossed1:
Users browsing this forum: CCBot and 45 guests
