EMUTos and ET4000
General Discussion, STOS.
frank.lukas
Re: EMUTos and ET4000
Post by frank.lukas »
The NVDIVGA.INF must be individually adapted for each graphics card and each adapter. The Version from me is for a VOFA Mega ST Bus Adapter and for a specific ET4000 ISA graphics card. If you use another ET4000 card you have to revise the INF. This can be done via the NVDI VMG program.
Use the Google Webside Translator -> https://forum.atari-home.de/index.php/t ... #msg261191
czietz
Post by czietz »
Afaik, no real-HW ET4000 card exists with 2 MiB of memory, because the ET4000 could only address 1 MiB in the first place. So, with every driver you're in "uncharted" territory, if your emulation comes with 2 MiB of video memory. Out of curiosity: What happens if you configure a 1024x768x64k mode with Nova VDI?
frank.lukas
ET4000W32i can do 2MB of Videoram.
https://www.microlabs.com
... only the old webside, shop is closed. There is a Nova W32i driver but 1MB only because with an 80Mhz RamDAC more than 1MB doesn't make sense.
czietz
Post by czietz »
frank.lukas wrote: Wed Aug 16, 2023 5:22 pm ET4000W32i can do 2MB of Videoram.
I know, Frank. That's why I wrote "the ET4000 could only address 1 MiB in the first place" and didn't write anything about the ET4000W32i, which is a totally different chip.
But we digress; dad664npc has an emulated ET4000. I just wanted to make the point that no driver will be known to work with an ET4000 with more than 1 MiB, because that does not exist (as real hardware).
frank.lukas
Yes.
He should build a ATI MACH32 Emulator or a ET4000W32i ...?
Return to “SOFTWARE”
