Kicad conversion of the Thomson MO5
sporniket
Re: Kicad conversion of the Thomson MO5
Post by sporniket »
Just reached a milestone in remaking the MO5 revision with the later gate arrays (EFCIS or Matra Harris) : all the tracing is done. Now starts the polishing phase, with the silkscreen, the BOM, and other details.
Capture d’écran du 2025-10-04 19-10-29.png (410 KiB) Viewed 89 times
HigashiJun
Post by HigashiJun »
Well done !
It looks really good.
Return to “8 BIT CORNER”
