Logic analyser recommendations ?
Re: Logic analyser recommendations ?
beel1 wrote: Wed May 31, 2023 12:15 pm Its protocol has been reversed and is supported by Sigrok it seems
https://sigrok.org/wiki/Sysclk_LWLA1034
Great thanks. I'll give it a go.
Started out as well as every other piece of software out there does :roll: .
OK I missed I need to get from archive.org it seems.
Windows reports the driver had been successfully installed, but the software simply does not find the programmer :roll:
beel1
Post by beel1 »
You probably need to install the libusb driver from Zadig: https://sigrok.org/wiki/Windows#Device_ ... USB_driver
Once detected you will also need the FPGA firmware/bitstream files: https://sigrok.org/gitweb/?p=sigrok-fir ... 6a;hb=HEAD
beel1 wrote: Wed May 31, 2023 10:31 pm You probably need to install the libusb driver from Zadig: https://sigrok.org/wiki/Windows#Device_ ... USB_driver
Okay thanks I will give that a try.
sporniket wrote: Wed May 31, 2023 10:32 pm I thought you were on linux now ?
My laptop is on Linux, but my main PC is win7.
Seems it was already installed but a slightly lesser version. Still cannot detect it in pulseview though :(
beel1
Post by beel1 »
exxos wrote: Wed May 31, 2023 10:53 pm Seems it was already installed but a slightly lesser version. Still cannot detect it in pulseview though :(
Someone tried this if it helps:
Finally got it working on all my Windows 7/10 Systems.
This is what i did, with Zadiag :
Install libusb-Driver, re-connect Device, install winUSB-Driver, re-connect Device, install libusbK, re-connect Device, then again installed libusb.
And voila, started Pulsview and all OK.
http://sigrok.org/bugzilla/show_bug.cgi?id=650#c25
Concerning the firmware, it's already bundled in the 0.4.2 release: https://sigrok.org/download/binary/puls ... taller.exe
I've tried that trick and still doesn't work. Think it's why I gave up before with the thing in the end. It must have only ever worked with xp on my laptop.
Return to “ELECTRONICS”
