In DISABLE mode, the only difference you may be able to pick up from a Falcon that simply doesn't have a DFB1(x) installed is that some addresses in the F1xxxx space now return results. This is the designated Falcon expansion memory zone and it's to allow reflashing the onboard ROM.leonk wrote: Mon Oct 13, 2025 2:36 am In off mode, I assume it works because the accelerator is able to jumper the correct pins on the CPU expansion slot to use the on-board CPU.
