As usual, a picture of a benchmark :-)
Picture is quite nice and filling the screen perfectly (it is a NEC 1990FXd connected via your ST2VGA adapter)
This is with 16MHz and STORM active, but since Gembench is running from the Diag Card, it is running from ST RAM
The NEC is also working with 15KHz in low and mid res.
Low res much better than mid…
Repeated the benchmark in mid res
Seems, the GEM and VDI performance is different, depending on the resolution…
Need to set-up a IDE adapter next…
LarryL's H5C1 build
LarryL
Re: LarryL's H5C1 build
LarryL
Ok, I call this build „done“ - for the time being…
Added a TOS/IDE Card I had laying around.
It is called TDEaL and contains two TOS2.06 EPROMS (soldered), which I deactivated, so only the IDE port is active.
Had to mod the Gotek stand a bit to make it work, since the TOS/IDE card was physically blocking nearly everything because of its layout.
Had to use IO Port #4 on top of the STORM for the IDE card and connected the CF reader by ribbon cable and a male/male adapter
Finally installed NVDI and made the obligatory benchmark :-)
