BOOSTER & DUALTOS
About the ST 16MHz simple booster.
dragmar
Re: BOOSTER & DUALTOS
Post by dragmar »
Ok. Yesterday I found time to solder the CPU stand. I ran the test at 16MHz at the beginning without the TOS 206 decoder. The booster started in 16MHz mode, the test carried out, made me realize that everything works very well. SYSINFO shows that atari works 8MHz, is that okay?
The time has come to rip it with DUALTOS. And here the failure does not want to work, I changed DUALTOS to decode from an external decoder and it does not work.
Should TOS 1.04 run on these settings as pictured? I switch between TOS 1.04/2.06 and it doesn't work.
Locked
Return to “ST 16MHz BOOSTER 2021”
