Sharp X68000 CZ-600CE - repair
HigashiJun
Re: Sharp X68000 CZ-600CE - repair
Post by HigashiJun »
rubber_jonnie wrote: Thu Jan 12, 2023 9:53 am
All the vids I've seen on these machines really do show how amazing the hardware is.
:dualthumbup:
Higgy
Post by Higgy »
Hi,
So looking at the 5.25" floppy drives I can't get them to read, I was using a known good disk.
I was not going to try and import some working ones (hate to think of the price!) so I decided to investigate the Gotek route.
There is some Japanese floppy emulators but they were either out of stock and expensive or just plain expensive.
From a Japanese website I found a guide where the floppy cable is modified to enable some ba5tardisation using a combination of Gotek and the original drives (for Eject and Signal Ready).
Not very exciting
Not very exciting
I tested it with a game needing just one disk, and it works :D
A bit more exciting
A bit more exciting
Joystick is MSX standard, and I have some Quickshot joysticks with Atari/MSX/Master System/Amstrad switch. I borrowed a friends PS/2 keyboard adaptor. But there is much more exciting news on Keyboard/Mouse adaptors at a later point :lol:
The X68000 really uses both disk drives with read access across both disks. I suppose knowing each X68000 has dual drives allows programmings to do this. So it was essential to have 2 drives, so I designed and printed some brackets to hold the drives together. I originally used an HxC Firmware drive, but FlashFloppy also works.
Dual Gotek.jpg (88.41 KiB) Viewed 4454 times
Here I was powering the floppy drives off an external 5V supply, but I planned to route 5V out from the PicoPSU.
I also tested, then bought a BlueSCSI V2 -> SCSI emulator using Raspberry Pico. Only problem now is memory, after booting an HD image my 1mb has reduced to 400kb :( Only enough to view some pictures and play sound files from the HD image.
1mb is not enough!
Dlfrsilver
Post by Dlfrsilver »
The floppy drives also have to be serviced, there are capacitors inside to replace by new ones, and clean also the acid :/
Higgy
Post by Higgy »
@Dlfrsilver - I spotted 1 of the miniature 100uF 16V caps near the power connector on both disk drives had leaked. I changed all 4 on both drives, full height caps fit. I also spotted on 1 drive some other miniature caps starting to leak so I will replace those.
I had to call upon my wife's Japanese cousin to help me with the memory upgrade. She did a cracking job and won this 1mb expansion for me on Yahoo Auctions:
1mb memory upgrade
1mb memory upgrade
She told me I am a 'Otaku' in Japan :lol: https://en.wikipedia.org/wiki/Otaku
Another really useful item someone has created is using a ProMicro, USB Host & level shifter for connecting Keyboards and Mice. I am now using a Logitech wireless keyboard and mouse :) Probably cost <£20 and I am really not that bothered in having an original keyboard and mouse.
I can do USB!
I can do USB!
I think this is a really important device because now you can buy 'Junk' X68000 towers, fix them and actually fully use them!
RetroTec
Post by RetroTec »
Thanks for posting the X68000 info, I have just got one an ACE model have built the Gotek cable but can only get a couple of images to load so far
just Arkanoid and Gradius, other images start loading but then stop, tried salamander and it wont load, I get some text and a flashing B> prompt
no luck with space harrier, r type, bubble bobble etc
I am using a single gotek connected via the internal IDE sharing cable using latest flashfloppy and using HFE images and a 1mb X68000
Higgy
Post by Higgy »
@RetroTec nice work!
Could well be the images, I know i had some issues when converting from the various X68K formats. Let me see about sending you a PM later to at least rule out the images.
UPDATE - PM sent
Return to “OTHER 680x0”
