exxos's DFB1 trials
Re: exxos's DFB1 trials
Badwolf wrote: Tue Jun 20, 2023 3:17 pm I'd play with the inline termination resistor on the CPU clock line. 100R, perhaps?
Good thought.
The clock looks pretty good how it is now. x1 scope probe and it seems a little more stable. This is why I put a buffer on there, But that has its own consequences :lol: :roll:
I just ran FPU test at 50MHz and it all passed. Though the keyboard is still acting up.
So this is 22R and 100R clocks.
It does seem more stable and the keyboard repeat does seem to work a lot more stable. However it locked up halfway through a GB6 run.
It does seem more stable with the scope on it still even on X10 :shrug:
But I do not think it is that simple, because looks like increasing the resistor had the same effect of adding the buffer in that ST RAM speed has now dropped I think.
The first few tests shows slower speeds.
RAM test alone locks up :(
Ironically the RAM test does seem to complete but it fails as above when trying to redraw the main window :shrug:
I don't really understand this because RAM test should be the simplest thing because the CPU would be running at 16MHz. So I suspect something is tripping up somewhere relating to ST RAM access @Badwolf ? :shrug:
Seeing the talk about sinking current etc. Would it be possible to only drive lines when they're low and go high-Z for high and let pull-ups do the work? Then you wouldn't risk one chip trying to fry the other.
stephen_usher wrote: Tue Jun 20, 2023 4:45 pm Seeing the talk about sinking current etc. Would it be possible to only drive lines when they're low and go high-Z for high and let pull-ups do the work? Then you wouldn't risk one chip trying to fry the other.
That's what BW's last code changes were to fix. I don't think any lines are actively driven high :shrug:
exxos wrote: Tue Jun 20, 2023 4:42 pm I don't really understand this because RAM test should be the simplest thing because the CPU would be running at 16MHz. So I suspect something is tripping up somewhere relating to ST RAM access @Badwolf ? :shrug:
Much more switching going on with an ST RAM test run from AltRAM. Should most certainly not turn out slower (I'd expect slightly over 100%). Perhpas 100R is too much as the amplitude of the 50MHz signal looks very low.
Your delay only applies to FPUCS, correct?
exxos wrote: Tue Jun 20, 2023 4:49 pm
I drive virtually everything all the time except when I specifically oughtn't. High speed and open drain generally don't go hand in hand.
Badwolf wrote: Tue Jun 20, 2023 4:55 pm Your delay only applies to FPUCS, correct?
Yep.
I have put the 22R back in now.
I've taken out AS from the clock switching code and it ran ST RAM test fine. I am running GB6 from alt-ram now and it locked up after a couple tests.
I just have to kinda assume the CPU can't do 50MHz.. But I don't really believe that exactly as they worked in the ST536. But I guess its a ST vs Falcon so something could be under more strain than on a ST I guess :shrug:
Maybe the cache in the 030 is causing ST RAM issues if it's trying to read from the cache and it gets corrupted that way and crashes.
Saying that, the TF536 does have the bus buffer/isolators which could be a factor in all this :shrug:
exxos wrote: Tue Jun 20, 2023 5:00 pm I've taken out AS from the clock switching code and it ran ST RAM test fine. I am running GB6 from alt-ram now and it locked up after a couple tests.
AS out of the clock switching code?! It'll be switching down on any matching noise on the address bus. Don't do that.
Ceramic CPU? I've never got a plastic to run relaibly at 50, but I know others have. Ceramic one really ought to.
Badwolf wrote: Tue Jun 20, 2023 5:08 pm Ceramic CPU? I've never got a plastic to run reliably at 50, but I know others have. Ceramic one really ought to.
They all ceramic. Though I have got 2 plastic which ran in the TF536 fine, but can't with one of the plastic ones even at 40MHz on the DFB1.
50MHZ CPU & FPU - GB6 in ST RAM
50MHZ CPU & FPU - GB6 in ALT RAM
50MHZ FPU TEST
Pink bucket
FIRST TEST OF ALT-RAM
64MB I presume ?
