Recreating the RSVE mod…
plouf
Re: Recreating the RSVE mod…
Post by plouf »
does any of these rsve still exist to buy one?}
thanx
Christos
frank.lukas
Post by frank.lukas »
I have PCB´s you can buy or a ready build up one. Also RS-Speed ones too ...
Pacman
Post by Pacman »
Does anyone know if the RSVE board is actually completely disabled (as if it wasn't there in the first place) when the computer boots up without the HSMODA drivers (DRVIN.PRG and MFP.PRG in the AUTO folder)?
I'm asking because if I plug something like a C-Lab Export into the serial port (it adds 3 MIDI OUT ports) I'm concerned the RSVE will still take processing power from the CPU and/or the MFP chip which could lead to timing instability and unreliability when using MIDI sequencing software. Is there any truth to this?
Do I need to add an enable/disable switch (see the STe schematic section below) so that I can physically disable it and bring the MFP connections together as the computer originally was set up?
RSVE with switch.png (270.97 KiB) Viewed 863 times
STe | MonSTer with dual IDE-CF memory card adapter | NEC Multisync 1990SXi | ST_ESSC | RSVE | Link '97 | Sony HD floppy drive/AJAX controller | Exxos HD floppy module | Battery-backed Ricoh realtime clock module | Discovery cartridge | C-Lab Unitor-2 | C-Lab Export | C-Lab Combiner | C-Lab Steady Eye | C-Lab Human Touch | Unicorn USB
💧Are you a good person? 💧Living Waters
