DFB1 Support thread
mfro
Re: DFB1 Support thread
Post by mfro »
dml wrote: Thu Nov 24, 2022 5:16 pm I was wondering the same - but the worst that can happen (if it just creates _FRB without visibility of TTRam) is that disk drivers see the _FRB and start using it. Which is benign, if maybe a little bit less efficient (maybe - not necessarily). So it might be the safest policy for a disk driver to just create one, MXAlloc'd from STRam, when it knows it is 'first in' before AUTO folder stuff.
I would think a more "natural" sequence would be to make maprom issue a warm boot when it's done installing itself and afterwards (when it's loaded again) detect it's already installed and just exit regularly (doing nothing).
This should allow to load the hard disk driver through the HD's root sector.
And remember: Beethoven wrote his first symphony in C.
markus0321
Post by markus0321 »
I put the MAPROM and HDDRIVER in the AUTO directory on the floppy and it also crashes now. For me, it doesn't even have bombs, it just freezes on the first attempt to click on anything. But before when I booted the system and clicked on MAPROM and then HDDRIVER it worked all fine.
markus0321 wrote: Thu Nov 24, 2022 5:48 pm I put the MAPROM and HDDRIVER in the AUTO directory on the floppy and it also crashes now. For me, it doesn't even have bombs, it just freezes on the first attempt to click on anything. But before when I booted the system and clicked on MAPROM and then HDDRIVER it worked all fine.
But which order is it loading in ? you would need to use AUTOSORT to verify which one is loading first.
markus0321
exxos wrote: Thu Nov 24, 2022 6:06 pm
From a floppy disk it starts so slowly that you can see in what order. But I must have made a mistake and started this old 8.04 hddriver manually. I'll do some more tests and write how it works.
It works fine even from a floppy in AUTO directory but only HDDRIVER version 8.04. Uwe wrote to me that the TT-RAM option in the HDDRIVER configuration applies only to the real TT-RAM in the Atari TT. I'll try to disable it somehow and do the same with HDDRIVER 11.13
markus0321 wrote: Thu Nov 24, 2022 6:09 pm From a floppy disk it starts so slowly that you can see in what order. But I must have made a mistake and started this old 8.04 hddriver manually. I'll do some more tests and write how it works.
Use HD11...I don't think we should be adding more variations at this point in time.
Also you could be booting the driver from the hard drive if not careful as well..
markus0321
exxos wrote: Thu Nov 24, 2022 6:14 pm
Okay, I'm checking now
markus0321
Done. From a floppy in the directory AUTO HDDRIVER 11.13 and trying to unpack the file = bombs
Same but HDDRIVER 8.04 = ok no errors
dml
Post by dml »
mfro wrote: Thu Nov 24, 2022 5:47 pm I would think a more "natural" sequence would be to make maprom issue a warm boot when it's done installing itself and afterwards (when it's loaded again) detect it's already installed and just exit regularly (doing nothing).
Yes. This is what I do with the 040 driver. Make changes resident, warm boot and let other software pick up changes on the subsequent boot pass.
However without that scenario, preemptively setting up _FRB is both benign and safe for the disk driver. Just not optimal :) I think it would be ok as a corner-case tickbox, probably not nice a default case.
markus0321 wrote: Thu Nov 24, 2022 6:36 pm Done. From a floppy in the directory AUTO HDDRIVER 11.13 and trying to unpack the file = bombs
Interesting..
Does HD 8.04 even support alt-ram I wonder ? Not exactly sure, but have a feeling that might have been in a more recent version :shrug:
markus0321
exxos wrote: Thu Nov 24, 2022 6:40 pm
Interesting..
I installed HDDRIVER 8.04 on a SCSI drive and booted from the SCSI drive normally, but unfortunately the errors occur again.
