CT63 only starts from 030 mode
Re: CT63 only starts from 030 mode
I think you need NVDI for it to be stable. Took me years to find that out :roll:
foft
Post by foft »
exxos wrote: Wed Sep 28, 2022 9:38 pm I think you need NVDI for it to be stable. Took me years to find that out :roll:
Thanks, that is actually one of the two things that was in my auto folder crashing it. I guess it's the other one then :lol:
coonsgm
Post by coonsgm »
Can you switch to resolutions other than 40 column double line on without it crashing?
I can boot kind of stably into TOS and run some software in that low res mode (also turning off Auto). I'm just glad I'm starting to see some progress.
foft
Post by foft »
coonsgm wrote: Wed Sep 28, 2022 10:25 pm Can you switch to resolutions other than 40 column double line on without it crashing?
I had this before sorting out the NVRAM. Perhaps reset your nvram (with the diagnostics cart - built-in).
Enabled NVDI in auto - still booting! wdialog too, still booting. Now for CPX... one at a time! nvdiconf.cpx -> boom! wdialog doesn't work, works without it.
coonsgm
Post by coonsgm »
Working much better and booting reliably at around 45mhz for the time being. Able to run multiple programs reliably as well, Gembench, STWord, Falcamp, Civilization, Ultima 6. Wow is it fast running all this fun stuff.
Still not able to change resolution post TOS boot...I can boot into any resolution, but changing using the standard TOS dropdown just errors out.
I figure this will keep me occupied for some time figuring things out. I really want to get basilisk running and see what I can do in some of the macOS environments.
I think my wife will appreciate it as it will keep me from purchasing other "projects"....at least for a little while.
foft
Post by foft »
Which gembench did you run? 4.0.3 was crashing on startup for me.
foft wrote: Thu Sep 29, 2022 8:12 pm Which gembench did you run? 4.0.3 was crashing on startup for me.
GB6 works fine on the CT60.
coonsgm
Post by coonsgm »
Gembench 6.31
It doesn't recognize the 060, but it shows the benefits of the speed here.
coonsgm wrote: Thu Sep 29, 2022 8:19 pm It doesn't recognize the 060,
That will be a cookie problem.
IF GETCOOKIE("_CPU",cpu&) THEN  'we found a cookie yum.
if cpu&=0 then GET_CPU$="68000"
if cpu&=10 then GET_CPU$="68010"
if cpu&=20 then GET_CPU$="68020"
if cpu&=30 then GET_CPU$="68030"
if cpu&=40 then GET_CPU$="68040"
if cpu&=60 then GET_CPU$="68060"
else
'no cookie so assume 68000
GET_CPU$="68000"
end if
IF GETCOOKIE("_MCH",mch&) THEN  'we found a cookie yum.
	if mch&=&h00000 then GET_MCH$="ST" : f=1
	if mch&=&h10000 then GET_MCH$="STE" : f=1
	if mch&=&h10010 then GET_MCH$="MSTE" : f=1
	if mch&=&h20000 then GET_MCH$="TT/HADES" : f=1
	if mch&=&h24D34 then GET_MCH$="MEDUSA T40" : f=1
	if mch&=&h30000 then GET_MCH$="Falcon" : f=1
	if mch&=&h40000 then GET_MCH$="Milan" : f=1
	if mch&=&h50000 then GET_MCH$="Emulator :(" : f=1
	if mch&=&h60000 then GET_MCH$="CT60" : f=1
	if mch&=-1 then GET_MCH$="NON-ATARI" : f=1
	if f=0 then GET_MCH$="UNKNOWN ST"
ELSE
	'no cookie booo
	GET_MCH$="ST"
end if
foft wrote: Wed Sep 28, 2022 10:06 pm Thanks, that is actually one of the two things that was in my auto folder crashing it. I guess it's the other one then :lol:
I put my CT60 page back up. I went through pure hell with the thing. There is a copy of NVDI which should be working fine. I think there is also bizarre patched versions of the control panel which could be screwing you up as well.
https://exxosforum.co.uk/atari/last/CT60/index.htm
