Honestly, you'd be way better off with HDDRIVER or PPeras driver.
ICD is old and clunky and will limit what you can do. More importantly, it won't let you use the SD card in Windows/Mac machines, which is a pretty useful thing to be able to do as it will allow you to interchange files between your ST and more modern machines with ease.
The disk preparation tools are considerably better than those for ICD too. You might find this topic useful: Setting up Ultrasatan
Geneva/Neodesk - how to?
Re: Geneva/Neodesk - how to?
Thanks guys! Will dig into it after work
C is reserved for my main ATARI partition with Programs and it works fine. Have no other letter which I could assign, so my guess is that I prepared PC card in a wrong way...exxos wrote: Thu Sep 01, 2022 10:56 am Afraid myself personally I have never used ICD tools. But in the gem menu, depending what version of TOS you have, will basically click one of the floppy drive a icons, then going to the options menu, install devices, and use a capital C. and see if you can access it.
Other things - I mean, mounting native partition on different cards and configurations run well so that's not an issue, I guess. I hope so.exxos wrote: Thu Sep 01, 2022 10:56 am There is also a problem of DMA issues on the STe in particular. So you could be running into any number of issues.
- viking272
Did you assign all the storage to C drive, so there is nothing left to make other partitions? (Which get assigned letters like D, E etc)
