Introducing myself
New user? Tell us about yourself!
12-MHz
Re: Introducing myself
Post by 12-MHz »
Dear Steve!
Steve wrote: Sat Jun 25, 2022 10:19 am I downloaded your 12mhz zip file, I am very intrigued but I don't speak any German. Do you have an English translation available?
Oh, sorry. This is a very old project. So it isn't available in English.
Also, does running the motherboard at 12mhz greatly benefit speed and benchmarks, I assume it would be very good! Is it stable?
Yes, indeed. My mainboard works since many years with 12,5 MHz (50 MHz oscillator) very stable. And you have got 150 % more speed in any cases.
Best regards
Robert
12-MHz
Post by 12-MHz »
Dear BigSteve!
BigSteve wrote: Sat Jun 25, 2022 3:08 pm As a fellow newbie that will be playing with Mhz shortly.... why 12Mhz and not 16? Some constraints I am going to run into...?
The MMU and GLUE are developed in a time, where is suitable to fix the timing between the signals with a greater delay like today. So the signals drifted away, if you increase the mainboard clock. Above 12,5 MHz most of the both custom chips from Atari doesn't work really good together, because some signals overtake other signals inside the both chips. It depends in great order from the right choose of this both chips. It isn't really stable above 12,5 MHz.
Best regards
Robert
12-MHz
Post by 12-MHz »
Hi!
DoG wrote: Sat Jun 25, 2022 4:44 pm
I haven't read the document so I don't know for sure, but I think it's the bus speed he is changing?
Yes! I do so. But it isn't easy to do this. Perhaps if you got a look into the document, you will see, that six signals and clock lines must be separated on the mainboard and new signals must be installed for video (2 MHz, 0.5 MHz, HSYNC, VSYNC, DE and Blank). Some signals should be added to the the pcb.
Best regards
Robert
Gruess, Robert!
Return to “INTRODUCE YOURSELF”
