DSTB1 exxos first tests & experimental firmware.
Re: DSTB1 exxos first tests.
exxos wrote: Fri Apr 22, 2022 5:41 pm Quick retest with a fan blowing on the thing this time...
Woah, that's odd. Shouldn't be any heat problem on the CPLD or RAM chip -- it ran happily here for hours. Your processor says 16MHz. D'ya reckon it's marginal?
Badwolf wrote: Fri Apr 22, 2022 7:47 pm Woah, that's odd. Shouldn't be any heat problem on the CPLD or RAM chip -- it ran happily here for hours. Your processor says 16MHz. D'ya reckon it's marginal?
I think it is likely to be the CPU. It has been kicking around my desk for ages. I got some new ones in a tube *somewhere* . But probably won't have time now to go look for them now, but will do Monday :)
*somewhere* I have some HC DIP CPUs...
exxos wrote: Fri Apr 22, 2022 7:53 pm *somewhere* I have some HC DIP CPUs...
*cough* 33MHz hack *cough*
Badwolf wrote: Fri Apr 22, 2022 8:13 pm *cough* 33MHz hack *cough*
*cough* PLCC68 socket *cough*
Well it has passed the "inserting it by one pin offset and powering it up test". It still works! :thumbup:
I have had it running with a small fan blowing on the thing for the past couple of hours and it seems fine..
exxos wrote: Fri Apr 22, 2022 9:50 pm
Well this was meant to have the dual purpose of an 'external' AltRAM board so the form factor was the decider for the DIP64.
Mind you, putting a PLCC68 socket on it would make it the direct reverse of the STE adapter board which has its own perverse attraction :P
OOPS...
exxos wrote: Mon Apr 25, 2022 3:27 pm Image
Woof!
With blitter @Badwolf
exxos wrote: Mon Apr 25, 2022 4:28 pm With blitter @Badwolf
Well now that's just showing off...
Badwolf wrote: Mon Apr 25, 2022 4:29 pm Well now that's just showing off...
:lol: :chairsmack: :cheers:
Will do some more tests than see if anything out of the ordinary happens...
LED working as well :)
