No.ottifant011 wrote: 06 Oct 2022 12:17 many thanks for the help.
does the gray cable have to be connected to ACSI10 for ide to work?
Are you running BLTFIX and the software in the package ? Has to be run in the correct order as well.
Nope. Don''t think so. Can't remember if the wire is needed for IDE or not. But I booted ultrasatan the other day without the wire.PhilC wrote: 06 Oct 2022 13:32 @exxos I thought we needed ACSI10 connected for the latest firmware? I have mine connected.
TK ?
Sysinfo doesn't get the right MHz so just ignore it.ottifant011 wrote: 06 Oct 2022 20:45 hm why is the 68030 only clocked at 8MHz?
or is that a misrepresentation
ACSI pin 10 hence its name.ottifant011 wrote: 06 Oct 2022 21:10 what would ACSI10 be connected to, I would like to try it and see if there is an improvement in terms of the IDE.
that shouldn't be a secret
Whilst that’s true, the integer division figure does seem high. Is normally around 1.8s for a 50MHz 030, IIRC. Suggests it’s running about half speed.DoG wrote: 06 Oct 2022 21:04Sysinfo doesn't get the right MHz so just ignore it.ottifant011 wrote: 06 Oct 2022 20:45 hm why is the 68030 only clocked at 8MHz?
Users browsing this forum: CCBot and 6 guests
