Whoops, I did it again! VIC-20 on the way...
Re: Whoops, I did it again! VIC-20 on the way...
Hmm, interesting:
Very nice work here, I suspect it's factory, but don't know enough to say what it's for. I'm guessing to replace missing or bad tracks on this version of mobo.
Seems to be using a few unused OR and NOT gates on the '02 and '04.
I can't see any references to those bodges on-line.
stephen_usher wrote: Wed Feb 16, 2022 2:58 pm Seems to be using a few unused OR and NOT gates on the '02 and '04.
It does seem to be, yes. Will have a look later too, see if I can find anything, Makes you wonder if some tracks were missed out.
I think I have an answer...
From what I've just read Commodore used larger RAM chips than was required as they had an over-stock, so I think this mod is trying to use the upper half of the RAM chips as a memory expansion. However, this was from Stack Exchange so it's probably wrong.
stephen_usher wrote: Wed Feb 16, 2022 3:02 pm I think I have an answer...
Interesting. I'm seeing only 3.5KB so it isn't using anything extra, or at least showing anything extra. Will dig more after work :)
Can the VIC=20 basic see more than that? I don't think that it can.
I've just posted that picture elsewhere to see if they know what the mod is.
stephen_usher wrote: Wed Feb 16, 2022 3:18 pm Can the VIC=20 basic see more than that? I don't think that it can.
It can be expanded via the cartridge slot to 32KB from what I've read, though I will be looking at other internal options.
stephen_usher wrote: Wed Feb 16, 2022 3:23 pm I've just posted that picture elsewhere to see if they know what the mod is.
Cool thanks. I did the same.
