Mega ST4, PAK68/3-030 without Fastram, ST-Low PAL 50Hz, Frontier run from Floppy
40Mhz with 32kB L2 Cache: 3095
50Mhz without 32kB L2 Cache: 1504
... I have only 35ns Tag Ram so 40Mhz is the max. For 50Mhz I need 20ns ones.
:o)
:o)
FrontBench: using Frontier as a benchmark (Discussion thread)
frank.lukas
frank.lukas
Re: FrontBench: using Frontier as a benchmark (Discussion thread)
Atari Mega ST4, EmuTOS 1.1.1, 8MB Alternate Ram, MC68010 8Mhz, boot with nothing in ST-Low PAL 50Hz
frames: 931
Alternate Ram has the same speed as ST Ram 3.7MB. Frontier run from floppy
frames: 931
That's an interesting one, Frank. Implies the 010 is approximately the same as doubling the 68k's frequency.frank.lukas wrote: 16 Feb 2022 15:56 Atari Mega ST4, EmuTOS 1.1.1, 8MB Alternate Ram, MC68010 8Mhz, boot with nothing in ST-Low PAL 50Hz
frames: 933
Odd indeed https://www.exxosforum.co.uk/forum/viewt ... f=42&t=861Badwolf wrote: 16 Feb 2022 16:08 That's an interesting one, Frank. Implies the 010 is approximately the same as doubling the 68k's frequency.
I'll see if I can find a 010 CPU when I get back home later..
68010 CPU 889 frames.
68000 CPU 878 frames.
czietz
My ST, PAL, stock (68000 @ 8 MHz) as reference: 882 frames.
... with Storm ST Alt-RAM: 906 frames.
... with Storm ST Alt-RAM and 68010 @ 8 MHz: 934 frames. <= confirms Frank's measurements.
Similar results are visible in CoreMark, too.
Thanks, guys. Recorded these on the github.
Also it implies AltRAM measuring the same throughput as STRAM doesn't quite tell the whole tale.
BW.
BW.
frank.lukas
Mega STE 4MB, 16Mhz 68000 + L2 Cache, Blitter off with +6MB Alternate Ram (MagnumSTE)
frames: 1556
The MagnumSTE works not with the Blitter so it´s switch off
frames: 1556
agranlund
Cool benchmark program!
Here's my Atari 520STM (PAL), with 50Mhz TF536.
Running from TT-Ram: 3073
Running from ST-Ram: 1407
My firmware is not stock though. Its got L1 enabled for Rom and ST-Ram access and I believe the stock one only does that for the onboard sdram.
ST-Ram cache misses are not cheap.. but it still makes an noticeable difference for stuff you can't run in fastram without loosing video (ie; framebuffer ending up in fastram)
Elethiomel
Nice! Can you share that firmware please? I'm getting 2940 on a ST536 Rev 5.agranlund wrote: 10 Apr 2022 15:48 Cool benchmark program!
