Cool, thanks.Laupert wrote: Wed Feb 02, 2022 2:42 pmYou could take a look at the Carnivore2 as well, which is a great expansion, though not sure if it is available at the moment.
MSX Inbound!!
Re: MSX Inbound!!
Cheshire Noir
Re: MSX Inbound!!
Carnivore 2 was my backup choice. The difference between the two seems minimal in terms of features.
Building the Omega was not without hiccups, and of course I found the "Here's a step by step guide with full testing and loads of helpful tidbits after I'd finished assembling everything.
I wrote it up here: https://ilike8bits.com/2022/01/13/build ... omega-msx/
TLDR: Finding the right ROM image was a little tricky. The LEDs on the keyboard go on top of the keys. Don't get the SRAM and EPROM confused.
Chesh
Chesh
Re: MSX Inbound!!
Cool, nice, you should do a little build guide on hereCheshire Noir wrote: Wed Feb 02, 2022 11:21 pm Carnivore 2 was my backup choice. The difference between the two seems minimal in terms of features.
Chesh
Re: MSX Inbound!!
CASDunio is good for tape loading and is cheap.
Also pretty simple to make your own.
I've only got one of those for my HX-10. Some carts have been converted to tape like Penguin Adventure (might have wrong name, but that impressive looking Konami game).
Re: MSX Inbound!!
Already have a Tapuino, supposed to work for Sinclair, Amstrad, MSX etc, just need the cable!Higgy wrote: Thu Feb 03, 2022 9:02 am CASDunio is good for tape loading and is cheap.
Re: MSX Inbound!!
I thought you needed to flash different firmware depending on if you wanted .CAS support. Maybe that's just the Arduino I am using.
Re: MSX Inbound!!
Well, it was advertised as doing it, once I get a tape cable sorted we'll see.Higgy wrote: Thu Feb 03, 2022 8:36 pm I thought you needed to flash different firmware depending on if you wanted .CAS support. Maybe that's just the Arduino I am using.
Cheshire Noir
Re: MSX Inbound!!
I used an old mobile I had lying around and a copy of MSX2CAS that worked fine for me.
Chesh
Chesh
Re: MSX Inbound!!
A huge thanks to @mrbombermillzy who sent me this:
It's the matching Toshiba HX-J400 joystick for my MSX machine.
I'm very grateful, thank you sir!
- mrbombermillzy
Re: MSX Inbound!!
No probs.
In fact, you can probably thank @Steve , for being the catalyst for me having to hunt around the 'hidden treasures' that are stashed away in the house!
