I am nocturnal I need a dark mode :)exxos wrote: 14 May 2021 14:43 @Icky Protested about not having a dark mode, something like "owwww my eyes my eyes is too bright my eyes.."
Server updates
Re: Server updates
Re: Server updates
Board and server updated... Though after finally getting it all to behave with php7... php8 is out now :roll:
Re: Server updates
@Badwolf - in that case we could do with an ST theme.Badwolf wrote: 14 May 2021 17:43 Dark mode is only for Amiga users. ST aficionados are used to dark text on light backgrounds, as is right and proper. :P
Re: Server updates
I have updated the stripe files for the store just. I have done a couple of purchases to make sure nothing is broken and it went through fine as far as I can tell... But if anyone suddenly get some odd errors or something then please let me know ...
Re: Server updates
But won't a mode that vivid hurt your eyes @Icky ?
Re: Server updates
Sooooo 1GB RAM does not look enough to run all the updated server software :roll: SQL Keeps intermittently crashing.. It looks like to make it repeatable, as I do a search for "exxos" on the new forum, which will hammer the SQL database, then open up 10 upload connections and filezilla.. Where those connections will stall for around 40 seconds, then RAM drops down to about 50MB free, SQL crashes, RAM jumps up to 200MB, filezilla connections then connect and upload perfectly fine, then when I go back to the forum and search again, well, around in circles we go ..
So will upgrade the server to a 2GB package and hopefully it will sort it all out.. Was really hoping the 1GB package would be enough :(
Re: Server updates
Making progress with the store order history & tracking system :)
Re: Server updates
Can someone check in their profile there is a emailed verified box at the bottom... It should say no, and not be editable, but I don't think its doing what its supposed to..
Re: Server updates
Do you mean the email address for store receipts etc?
It's there on mine but says "No"
Re: Server updates
Yep... it says NO by default, but can you edit it ? as its supposed to be disabled from edits, but it's letting me edit it :roll:JezC wrote: 18 May 2021 16:43 Do you mean the email address for store receipts etc?
Users browsing this forum: CCBot and 48 guests
