Good to hear that you got a quick response there. If they are puzzled, that bodes well for a solution. :mrgreen:exxos wrote: 20 Feb 2021 15:44 Getsll has replied and looking into it.. I think he's a bit puzzled as well..
Server updates
derkom
Re: Server updates
Re: Server updates
So apache is still loading the old cert dispite me putting in the new certs... BUT.. I'm wondering if I've done something dumb...
In the sites enabled folder, does anyone know if apache loads *all* files in there, or just the ones ending in .conf? Because I was putting XXX on the end of some to disable them ( reloading apache ) but I can only think apache is still loading them which has the old certs listed.. Its the only place I can see apache is getting the old info from...
I've deleted the files, but I can't restart the server until I get back home... Meanwhile does apache load site info from anywhere else, other than apache.conf that is ?
derkom
Re: Server updates
This is under the control of your main apache2.conf* file. Typically it'll include a line like "IncludeOptional sites-enabled/*.conf", which as you can imagine will load only files ending in ".conf". You should have a look at your own apache2.conf to verify, but this is probably what you have as well.exxos wrote: 21 Feb 2021 00:21 In the sites enabled folder, does anyone know if apache loads *all* files in there, or just the ones ending in .conf? Because I was putting XXX on the end of some to disable them ( reloading apache ) but I can only think apache is still loading them which has the old certs listed.. Its the only place I can see apache is getting the old info from...
Sometimes if I want to be very sure that a config file isn't getting loaded, but for some reason I don't wish to simply move it out of the directory, I'll gzip it. Nothing is going to read a gzipped config file, so at worst I'll get an error if it tries to parse it anyway. Then I can be sure the file isn't being loaded, and I don't have to figure out later on where I stashed it.
Again this is under the control of that master configuration file. Look for "Include" and "IncludeOptional" lines in your master apache2.conf, and do bear in mind these commands can cascade, so if any included files contain their own Include directives, you need to follow the tree on down.I've deleted the files, but I can't restart the server until I get back home... Meanwhile does apache load site info from anywhere else, other than apache.conf that is ?
* Your main configuration file may be called something different, depending on your specific installation.
Re: Server updates
Indeed, it's snapd which is the issue, as that only supports a small subset of distributions.derkom wrote: 20 Feb 2021 15:22Really? Looking at https://certbot.eff.org/, I see a whole slew of Linux distros supported, including "other Linux" (which unfortunately requires installing snapd, but it's an option at least), as well as FreeBSD, OpenBSD, macOS, and Windows.stephen_usher wrote: 20 Feb 2021 12:34 Certbot changed their distribution and install method, which only supports a very small number of "blessed" Linux distributions. They broke it for all other distros and operating systems.
derkom
Re: Server updates
Gotcha. I have managed so far to avoid going down that path... :Dstephen_usher wrote: 21 Feb 2021 09:38 Indeed, it's snapd which is the issue, as that only supports a small subset of distributions.
Re: Server updates
Yeah , its not those files :( I may brute-force it all and just rename the lets encrypt folder so Apache simply can't load the certs, then see what errors and trace it that way.derkom wrote: 21 Feb 2021 07:05 This is under the control of your main apache2.conf* file. Typically it'll include a line like "IncludeOptional sites-enabled/*.conf", which as you can imagine will load only files ending in ".conf". You should have a look at your own apache2.conf to verify, but this is probably what you have as well.
derkom
Re: Server updates
The words of a man with a lot of experience working with cantankerous retro hardware. Halt and catch fire. :lol:exxos wrote: 21 Feb 2021 11:30 I may brute-force it all and just rename the lets encrypt folder so Apache simply can't load the certs, then see what errors and trace it that way.
Re: Server updates
:lolbig:derkom wrote: 21 Feb 2021 13:05 The words of a man with a lot of experience working with cantankerous retro hardware. Halt and catch fire. :lol:
Yeah, crash and burn all the way baby :lol:
Expect the forum to die around 9pm tonight :lol: :roll:
Re: Server updates
Sooo
all variations of exxoshost.co.uk (www / http etc) *should* now load , and *should* have a cert which expires in 3 months time...
The problem was indeed the files I had in sites-enabled, I have like domain-ssl.confXXX where XXX I thought would stop apache from loading them.. but how wrong I was! I deleted the files instead and now apache seems to be loading the new certs!
Re: Server updates
My store was erroring relating to the chain.crt missing in my apache config.. so I was getting order payment emails, but no actual orders...
There was only 1 order today which got "lost" (and now fixed) , so nobody needs to worry about missing orders..
Users browsing this forum: CCBot, trendiction [bot] and 5 guests
