Creating partitions on real HDD from Hatari?
General Discussion, STOS.
mrbombermillzy
Re: Creating partitions on real HDD from Hatari?
Post by mrbombermillzy »
Steve wrote: 03 Nov 2021 13:53 @mrbombermillzy That is odd, certainly not a simple clock-patch issue. Would need to look at the DSP soldering & SDMA clock line. If you're gonna do some pictures & trouble shooting perhaps split into a new topic I think.
Well, I wasnt too bothered about hijacking my own finished topic thread :lol:
But yes, you are right.
I was going to send you some pictures to see what you think next time I get the Falcon out.
I'm not sure that any board revisions that have been done did actually work correctly, as I never had the board in a fully working condition.
Will PM you with more details when I can get to it.
Oki doki :)
mrbombermillzy wrote: 03 Nov 2021 13:19 However, there is only the YM sound. DSP and SDMA either cause errors, lock up the machine, bomb out, or are just silent.
Interesting failures. What does DSPDUMP (attached) say, straight after boot?
Normal would be
00 12 06 0f 00 00 00 00
Cheers,
BW.
mrbombermillzy
Thanks BW.
Here's the result straight after desktop boot from CF HDD w/ custom PPera HDD driver:
Will get some 'good' photos of the mainboard when I have decent enough lighting conditions.
OK, that's also interesting.
You'd expect no DSP at all to yield all FFs there. The fact you're getting something, albeit nonsense, is at least a data point.
I've had all sorts of grief getting the DSP to accept writes (see other threads), but I've never had trouble getting it to read that wasn't timing related.
The fact there is anything other than FF or 00 on the last four bytes leads me to think it's not the DSP responding, but something else (or the DSP is truly broken!).
Depending how deep down the rabbit hole you want to go, U44 is worth looking at. The DSP selection and response is entirely co-ordinated by the GALs, COMBEL doesn't get involved. The interaction between them is complicated, though. The absolute final piece in the jigsaw is pin 15 of U44 -- DSP_CS. This tells the DSP to either write or accept data on the bus. You *could* try removing U44, bending that pin up a little and re-inserting without it. I would expect you to then see eight FFs in DSPDUMP.
Unfortunately pulling U44 completely will, I think, result in a hung boot.
Have any of the old mods had anything to do around the four GALs at the front of the board and U44 tucked up by the floppy?
mrbombermillzy
Hi again BW.
Thanks for the help.
I have continued the topic here: https://www.exxosforum.co.uk/forum/viewt ... =23&t=4805
Return to “SOFTWARE”
Users browsing this forum: CCBot and 7 guests
