MegaST - something recient.
Re: MegaST - something recient.
I personally would make the assumption you have a bad connection on your CPU socket somewhere. I suggest you go back to square one and start continuity checking every pin on the CPU to things like the MMU & GLUE etc.
ok.. god knows that has had a lot going in and out in the last couple of years.. so that could be it.
but if it starts working, and goes bad.. how do I find the bad connection.. if the connection is good when cold?
James
James
While testing continuity push various places on the board about a bit..
Well no luck with that.. everything checked out ok, from CPU to all points I could find. pushed the board, but did not flex it hard or anything.exxos wrote: Fri Oct 29, 2021 9:11 pm While testing continuity push various places on the board about a bit..
I guess I will try some memory chip substitution. I can put things together and take them apart, but my logic troubleshooting is not there. Might be an easy fix, but I am not aware how to trace it down.
James
Before you do that, seeing as it changes with time, and hence heat, use a freeze spray to see if you can localise the problem. You don't want to create more faults whilst diagnosing the first.
Could you be more specific Stephen?? can of compressed air??? and where would you suggest I spray??stephen_usher wrote: Sat Oct 30, 2021 2:55 pm Before you do that, seeing as it changes with time, and hence heat, use a freeze spray to see if you can localise the problem. You don't want to create more faults whilst diagnosing the first.
james
Well, some air cans can work as freezer sprays by turning them upside down. These are usually the flammable ones.
Where to freeze? anywhere where the data bus goes. Try the CPU area, MMU, RAM just to see if spraying any chips (or area of the motherboard) makes a difference to the behaviour.
So I have never done the spray before Stephen, I have some now.. am I starting up the machine and spraying an area before things go bad? after they go funky? before I turn it on??stephen_usher wrote: Sat Oct 30, 2021 10:32 pm Well, some air cans can work as freezer sprays by turning them upside down. These are usually the flammable ones.
Wait until it heats up to go bad.. turn it off.. spray.. and try again??
James
Leave the machine on, and when it starts failing, then spray select locations on the board and see if the fault disappears.
I would advise keeping it away from the power supply as some sprays can be highly flammable.
thanks exxos, this one does say non flammable.. I was always under the impression extreme cold hurt electronics as well.. I am guessing just a little blast should give me results.exxos wrote: Tue Nov 02, 2021 2:43 pm Leave the machine on, and when it starts failing, then spray select locations on the board and see if the fault disappears.
So, start at the CPU I am guessing because we thought originally issues might have started there??
James
