Hi all,
Good news today I receive my new MFP and it's working, except the keyboard, but the Atari is running, with working disque drive and semi working hard drive.
I have to wash the keyboard and reassemble the mousse to make more test.
I will give you more news later, thank's to all for the support.
1040 STf error i6
DoG
Re: 1040 STf error i6
There is two MC6850P (ACIA) that you can swap with each other. One is handling the MIDI communication and the other is handling the keyboard. Clean with IPA. Reseat in socket (if it is in socket).
Atome_X
Hi DoG,DoG wrote: 28 Sep 2021 15:21 There is two MC6850P (ACIA) that you can swap with each other. One is handling the MIDI communication and the other is handling the keyboard. Clean with IPA. Reseat in socket (if it is in socket).
The keyboard is working, I have 32 key not working, I have order Loctite contact to try a reparation.
Atome_X
Hi all,
Some news about my STf reborn, I have repair all the key (working and not working) with Loctite MR3863, FDD is working, Megafile 30 is working I have updated the driver to 6.061.
The last things I have to do is repair the SM124, the light and contrast is very low, if you know what it can be it will be great.
Thank's to your help, regards.
Cyril
Cyril
How many hours has the SM124 been running? CRTs get dimmer with age as the cathode degrades.Atome_X wrote: 12 Oct 2021 13:33 Hi all,
Cyril
Please open up a new topic about this as is not on the same subject to the initial posts.Atome_X wrote: 12 Oct 2021 13:33 The last things I have to do is repair the SM124, the light and contrast is very low, if you know what it can be it will be great.
Users browsing this forum: CCBot and 54 guests
