Locked
Which makes sense as you'd put the dip socket on that board instead, which also makes more sense from a reliability point of view with dips being less did say about bad connections.
So I will probably leave the booster in the STE for now.
Will happily be a guinea pig again for the sec booster once you've created it, as will fix up the new STFM hopefully over the weekend.
Forgottenmyname wrote: Tue Oct 30, 2018 8:46 pm Which makes sense as you'd put the dip socket on that board instead, which also makes more sense from a reliability point of view with dips being less did say about bad connections.
The header pins on these things are so tiny and not easy to get to either. It be a lot easier to have normal header pins like the STFM boosters.
2 of these new STE ones are not working.. no idea why, but its like 50% failure rate so far :roll:
I can imagine. Far too easy to create a dry joint or to bridge two pins.
troed
Post by troed »
I have a feeling I've asked this once and now forgotten what the answer was. Sorry, but:
Can these be switched between 8/max while running, without the STE locking up?
troed wrote: Tue Oct 30, 2018 9:58 pm I have a feeling I've asked this once and now forgotten what the answer was. Sorry, but:
They can switch in real time yes... They actually do that when accessing the ACIA anyway.
troed
Post by troed »
Alright, time for me to get one then :)
(secret mission: New GAL project to switch from software)
troed wrote: Tue Oct 30, 2018 10:09 pm (secret mission: New GAL project to switch from software)
Cool! Might actually get that integrated into the SEC booster ,so choose a good register ;)
PaulJ
Post by PaulJ »
exxos wrote: Tue Oct 30, 2018 8:57 pm
I'll add my 2 cents which canbe taken with a grain of salt. I've been doing embbeded software since there was such a thing. I have spent lots and lots of time trouble shooting hardware and I can assure you your much better off without sockets. All sockets are is a potential bad connection. I can't tell you how many times I ran into boards where the golden rule was to reseat all the chips. A few times of that and you have issues that continue to multiply. The milled pin dips are the only socket I have any confidence in. I have a st1040 with the 1.5 booster, 4 mb sim memory upgrade, and fast rom boards which are all soldered in. Thing is solid as a rock. In general sockets are just like drugs... just say NO. Socketed upgrades are easier to install but there not as reliable.
PaulJ wrote: Tue Oct 30, 2018 10:52 pm I'll add my 2 cents which canbe taken with a grain of salt. I've been doing embbeded software since there was such a thing. I have spent lots and lots of time trouble shooting hardware and I can assure you your much better off without sockets. All sockets are is a potential bad connection.
I take it you have not seen this post then ?
https://www.exxosforum.co.uk/forum/viewt ... ?f=23&t=74
The first ste booster was solder in, because of socket issues... Problem is, most people destroyed their ste in the process... So I did a plug in booster which is the lesser of the 2 evils for people.
PaulJ
Post by PaulJ »
exxos wrote: Tue Oct 30, 2018 11:07 pm
I did see it not to mention I had the similar experience with your glitter and socket converter that had extremely strong socket contact springiness. When I put that glitter in the board it did not work because I believe the glitter pins were compressed enough so they all didn't make contact with the weaker sockets I used on the board. Popped a glitter out of an mega and it worked fine. Never the less sockets are trouble!! As you point out. You should be commended for making the effort to have plug in enhancements for the soldering challenged among us although it makes the effort much more challenging. :thumbup: :thumbup:
Locked
