Problem with H4 not booting (zChris's board)
Re: Problem with H4 not booting (zChris's board)
Very true @exxos and it was because this was the most Reliable board that I have with the smt chips is why I sent it to zChris.
zChris
Post by zChris »
Ive measured the MAD lines and they pulsates with 2Mhz to 4Mhz according to the oscilioscope.
/zChris
zChris wrote: Thu Aug 19, 2021 7:20 pm Ive measured the MAD lines and they pulsates with 2Mhz to 4Mhz according to the oscilioscope.
/zChris
So it sounds like the MMU is working which is good.
This might be time consuming but try this, remove the dma and see if the cpu /halt line now stays high after the reset.
zChris
Post by zChris »
PhilC wrote: Thu Aug 19, 2021 7:36 pm
/zChris
I'm not sure i did it right but this is what i did. I removed the chip that's on the "BAD DMA" socket, that's the DMA right? Then i measured HALT line, pressed the reset, it goes low, released reset and it goes high after a short time.
/zChris
@zChris So the Glue is halting the system.
In one of your photos it looks like there is a bridge on one of the GLUE pins, can you take a clear close up photo of it please.
zChris
Post by zChris »
Yeah sure
EDIT: Hmm cant make the image clickable to view the big one for some reason. Hope this work.
/zChris
DoG
Post by DoG »
The pins next to C21? Pin 69-70 (A12-A13) looks joint.
zChris wrote: Thu Aug 19, 2021 8:55 pm Yeah sure
/zChris
@zChris - reason for the image not working is you need to place it in the post correctly. Instructions here - https://www.exxosforum.co.uk/forum/viewt ... =20&t=2357
I have done this for you already on that image.
DoG wrote: Thu Aug 19, 2021 9:01 pm The pins next to C21? Pin 69-70 (A12-A13) looks joint.
Good spot @DoG - looks like solder blobs just nestling inside the pins of the SMT
zChris
Post by zChris »
I have done an ohm measurement on all the GLUE pins and none of them had connection to a neighbouring pin.
/zChris
