Problem with H4 not booting (zChris's board)
Re: Problem with H4 not booting (zChris's board)
Just to be sure you're not using a DIP CPU *AND* a PLCC CPU ?
zChris
Post by zChris »
Yeah, only have 1 CPU and thats PLCC.
/zChris
zChris wrote: Tue Aug 17, 2021 5:49 am Yeah, only have 1 CPU and thats PLCC.
The image shows DIP CPU ?
exxos wrote: Tue Aug 17, 2021 2:29 pm
I'm in agreement, the photo shows a DIP CPU present.
zChris
Post by zChris »
Ah alright, then its DIP.
/zChris
zChris
Post by zChris »
Alright, have done some measuring of frequency today. All the chips had signals present except MMU where i could not read a signal on Pin5 (16Mhz) and on Pin 19 and 20 it fluctuated between 2 and 4 Mhz. The measuring was done with the reset button NOT pressed in if that matters.
/zChris
zChris
Post by zChris »
After looking at https://www.exxosforum.co.uk/forum/viewt ... f=31&t=149 i saw that it was different pins on the SMD version of MCU (MMU) so after measuring again it i have found 4Mhz , 8Mhz and 16Mhz on that one aswell.
/zChris
You need to check ROM0,1,2 on the GLUE after reset .. But you need to put your scope in a one shot mode. I don't remember of hand where the setting is but without it you might miss the signals as they are very fast.
zChris
Post by zChris »
Alright, what am i looking for on those lines ?
/zChris
zChris wrote: Wed Aug 18, 2021 6:05 am Alright, what am i looking for on those lines ?
/zChris
They should be pulsing low. IIRC ROM should pulse first after reset.
