Wow, 2023 since I was last here.
Well I have the board back out, have not got the pistorm thing.. most likely wont.
I am reducing my hardware now - getting old - need to slim down the hobby room or Ill be looking for a new room to put stuff in :shock:
I had a 2.2 booster - I put it in the H5 - seems to be working fine. Question is, im using a ACSI2STM compact device on the rear. and it uses a satandisk compatible clock with backup that I have set the date to. But when I use US_GET.tos to get the time and set the clock. It will set the time but not the date. I cannot think of anything on the H5 or the Booster that would have issues with this. But worked with TOS 1.04 but not 2.06 - could this be a decoder issue?
Anyone with a thought?
James
Bikerbob's H5 C1 build
Bikerbob
Users browsing this forum: CCBot and 62 guests
