TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
8 Bit Dreams
Re: TF1230 Beta Interest (Open Source)
Post by 8 Bit Dreams »
Built two, just to be sure, both behave identically..
Tried white/blue Chinese CF and SanDisk, both 8GB PFS Filesystem
Original 3.1KS PROM'S
go0se
Post by go0se »
8 Bit Dreams wrote: Thu Sep 30, 2021 10:09 pm Built two, just to be sure, both behave identically..
CPLDs from the same batch in both cases? From a reputable source or reprints?
8 Bit Dreams
CPLDs are known good from DigiKey, MB is freshly recapped,
TF1260 works great on it....
will try to use some EPROMs, maybe this helps 🤔
ICRY
Post by ICRY »
Hello all
Good evening my build of the the TF1230, gone smoothly 68030 shows up, just one odd thing the ram is a no show, in workbench or Amiga test kit, checked my soldering looks good, any pointers there might be a bad joint...that I've missed, or I am best test with 3.1 roms, & sorry if has been covered before
A1200 rev 1b
Kickstart 3.0
Cpld flash with tf1230r1_2021_09_14_RC1
ICRY wrote: Thu Sep 30, 2021 10:18 pm Hello all
A1200 rev 1b
Kickstart 3.0
Read up... Kick 3.0 not supported. Try 3.1+
arkadiusz.makarenko
Post by arkadiusz.makarenko »
If you don't have 3.1 at hand, you can try addmem (https://aminet.net/package/util/cli/AddMem)
~ Stanislaw Lem
Danoo
Post by Danoo »
MT48LC16M16A2P-6A-G installed, rock solid for many hours of testing on a 1D4 and 2B (31 and all types of ROMs). Also tested on a 1D1 for a short while with no issues.
Life is really simple, but we insist on making it complicated - Confucius
alenppc
Post by alenppc »
Danoo wrote: Thu Sep 30, 2021 11:51 pm MT48LC16M16A2P-6A-G installed, rock solid for many hours of testing on a 1D4 and 2B (31 and all types of ROMs). Also tested on a 1D1 for a short while with no issues.
So that’s another ram type that supposedly doesn’t work. So it seems it’s completely random whether the 1230 will work or not on any given motherboard… :/
Aeberbach
Post by Aeberbach »
MT48LC16M16A2P-6A-G - same RAM as I used - I bought it for the 536 but it was left over. Has been working fine on the 1D4.
alenppc wrote: Fri Oct 01, 2021 2:23 am So that’s another ram type that supposedly doesn’t work. So it seems it’s completely random whether the 1230 will work or not on any given motherboard… :/
Indeed. I have 5 motherboards now and everything works on all of them.
Another thing that has been noted is that less issues are seen when the RAMOE line is grounded... let me add a jed file here with that set that way all the time...
tf1230r1_2021_10_01_beta.zip
(24.81 KiB) Downloaded 290 times
The only other thing i might suggest as a mod to try is to cut the CLK14M line from the A1200 and put a tiny clock buffer IC in like on the TF520. That might make a difference and if we can verify that we could update the design.
The reason i didnt do this out of the gate is because it can introduce ringing and the rise time of the 14M clock on the A1200 seems to be good enough to sample with the CPLD.
Return to “TF330”
