TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
8 Bit Dreams
Re: TF1230 Beta Interest (Open Source)
Post by 8 Bit Dreams »
terriblefire wrote: Fri Sep 10, 2021 1:18 am Initial hypothesis is that the Rev2B vs Rev 1D4 (et al) do autovectors differently. Not sure *HOW* this happens but I can see that interrupts are processed by an AVEC on the Rev2B and VIA DSACK on the 1D4. Since the autovector is pulled out of ROM with DSACK processing this explains why ROM speed makes a difference.
Nice catch Stephen! 👍
I've red about AUTOVEC some time ago...
In the event of an interrupt, the 68000/010 looks into the VBR ((Interrupt) VectorBaseRegister) + interrupt offset (1-7) and jumps to this address for the interrupt service routine. This is the classic "Autovector / AVEC" approach. Advantage: simple. Disadvantage: If several devices trigger the same interrupt (INT2 / 6), the interrupt routine must first cause the system to query all possible (registered) triggers: "IDE, was that you? SCSI, was that you ?, CIA, was that you? PicassoIV, was that you? " - works slowly...
The 68020 CPUs and above have a second mode: The interrupt-generating device places the jump address on the data bus with a certain function code (similar to an FPU command). So every device could bring its own interrupt routine with it. Problem: The interrupt service chip (Paula) cannot do that. Therefore it has to be turned off. Now Commodore has had problems itself and has used a "trick": The highest addresses of the Kickrom are exactly where the CPU expects the jump vector. That's why Commodore simply copied the AVEC jump vectors there again. Thus the CPU could serve "pseudo interrupt vectors", because of that different KS versions may work different... 🤔
Few more things .... see how this one is...
<deleted>
supaduper
Post by supaduper »
Sorry Bud no difference for me still blank screen :(
kulamario
Post by kulamario »
terriblefire wrote: Fri Sep 10, 2021 6:07 pm Few more things .... see how this one is...
Now I done test on last firmware still no boot from HD
when I do memory test in ATK I got this
Now I repeat the test twice times ATK stop exactly in same place
arkadiusz.makarenko
Post by arkadiusz.makarenko »
I can reproduce issue with RAM.
Of course it still may be my awful soldering skills.
~ Stanislaw Lem
kulamario
Post by kulamario »
I tested another tf1230 same result but error start at 0x8600000
so it seems to me that we can rule out the soldering problem
8 Bit Dreams
Yeah, seems it is ram timing that craps out at some point.. :idea:
You guys have same type of ram?
supaduper
Post by supaduper »
I think the Mem test that are being shown here are rabbit holes as I am sure that SYSTEST Mem test wont work with the boards and never has done from the TF330 , anything with MMU just craps out, can you verify that Steve ?
alenppc
Post by alenppc »
supaduper wrote: Fri Sep 10, 2021 9:08 pm I think the Mem test that are being shown here are rabbit holes as I am sure that SYSTEST Mem test wont work with the boards and never has done from the TF330 , anything with MMU just craps out, can you verify that Steve ?
This only happens when the MMU is in use, but either way you are right that you guys are barking up the wrong tree. There is nothing wrong with the ram, there are other things at play here.
arkadiusz.makarenko
As a tester, I do my best to report unexpected behaviour and I try to reproduce issues reported by other people.
I do not suggest the cause, as I don't have enough knowledge to do it ,but still I think it may be relevant to TF in troubleshooting.
Ps.
And tonight I choose to drink Tequila, while playing with Amiga ;)
~ Stanislaw Lem
Return to “TF330”
