TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
kulamario
Re: TF1230 Beta Interest (Open Source)
Post by kulamario »
supaduper wrote: Sun Aug 29, 2021 2:56 pm
kulamario wrote: Sun Aug 29, 2021 2:48 pm
I don't think this is the cause I have Budgie rev0 on 1D and 2B boards
Boards 2B working perfect but 1D only on kick 3.2
Yes I understand, but you do have a Rev 0 on the 1D4 same as me, and no boot :)
need someone else with a working 1D4 just to see what revison Budgie they have
TF brought such yesterday 1d
Avinitlarge
Post by Avinitlarge »
Mine is a Rev 0
arkadiusz.makarenko
Post by arkadiusz.makarenko »
Avinitlarge wrote: Sun Aug 29, 2021 2:06 pm 3.1 with no drive, boots
3.1.4 with no drive, Boots
3.2 with no drive, Boots
This is with a BooBip rom switcher
Avinitlarge wrote: Sun Aug 29, 2021 5:05 pm Mine is a Rev 0
~ Stanislaw Lem
8 Bit Dreams
Post by 8 Bit Dreams »
Ok, burned KS 3.2 - 1D4 is not booting no matter 3.1 or 3.2
it's an Escom Model with Gayle -R5, HP LISA & Budgie Rev.0
GadgetUK164
Post by GadgetUK164 »
Just throwing in an idea - it's not about that clock bodge that Commodore fitted is it? They did it so many different ways between boards (even same rev from what I've seen). In this area here:-
8 Bit Dreams
Well, I have a resistor fitted here:
GadgetUK164 wrote: Sun Aug 29, 2021 8:53 pm Just throwing in an idea - it's not about that clock bodge that Commodore fitted is it? They did it so many different ways between boards (even same rev from what I've seen). In this area here:-
The weird bit is the approach is the same on TF330/360/1260 and 1230... So its a little confusing why the issue it is there in only one board and only on the 030
dalek
Post by dalek »
So that resistor bodge is pulling the CCK CLK line up to Vcc? Presumably trying to improve rise time/drive strength?
Would be interesting to see that signal on a scope with/without the resistor bodge.
EDIT: so it's cheaper version of this fix which used a clock buffer chip: https://www.tsb.space/knowledge-base/am ... ump-wires/
Both my 1200 1D4 are rev0 budgie and they have the resistor
8 Bit Dreams
terriblefire wrote: Sun Aug 29, 2021 10:51 pm The weird bit is the approach is the same on TF330/360/1260 and 1230... So its a little confusing why the issue it is there in only one board and only on the 030
indeed it is a bit confusing, Blizzard IV 1230 ist working on the same setup... 🤔
Additional IDE is completely disabled atm, right?
Return to “TF330”
